Garmin GPS receiver locations >
Old 03-06-2005 | 10:25 PM
Havasu Cig's Avatar
Default Re: Garmin GPS receiver locations
The Skater I just bought has the antenna under the deck. The deck is very thin though so I don't know if that would make a difference.
Havasu Cig is offline
Old 03-06-2005 | 10:29 PM
Titan's Avatar
Originally Posted by GLH
It's on my radar also (pardon the pun) but most new rides (OL, NorT, Cig)these days are coming out with Garmins I am not big on going off the beaten track (always considering re-sale). Also if the receiver I currently have works than no way am I installing anything different.
I understand GLH all you Cig guys have to all be alike. I will let you play with mine at the Milk Run and you can tell me what you think...
Titan is offline
Old 03-06-2005 | 10:30 PM
offshoredrillin's Avatar
west marine has the 2006C for 1549.00 wonder if it will fit in the same spot?
offshoredrillin is offline
Old 03-06-2005 | 10:46 PM
GLH's Avatar
GLH
Yahhh I'm ever the trend follower!!!
Here is the funniest post about me I have ever read here!
Originally Posted by BattleCry
GL
Both times I met you, once in Miami, once in Key West, you were operating on some other channel than the rest of the world.
GLH is offline
Old 03-06-2005 | 10:50 PM
GLH's Avatar
GLH
I've seen it around $1250 I think the hole needs to be a bit bigger but it still fits in that spot.
I'm more concerned about having something on my deck that looks like mushrooms growing, here in Vermont all the deadheads, phish fans and the " Nothing wrong with that "crowd would try to munch it.
GLH is offline
Old 03-06-2005 | 11:24 PM
Ted G's Avatar
Actually the mast mount is removable from the bottom which leaves you with a white hockey puck.....but then you are liable to end up with drunken Canucks in ice skates trying to swat at the thing on your dash
www.cbpba.com
Ted G is offline
Old 03-07-2005 | 12:08 AM
Donzi38ZX's Avatar
I have the GA-29F shown here. I was unable to remove the mount from the standard GA 29.
Donzi38ZX is offline
Old 03-07-2005 | 04:33 PM
you can also mount it in the cabin out of site, just have to mess with it a little bit to see where it gets the best position, then not on the dash. You can also take and drill the hole a little bit bigger that the shaft so the mushroom will sit flat and epoxy it in, or caulk it in as well.
JPD Motorsports is offline
Old 03-07-2005 | 04:48 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Before you do anything, try hooking it up under the dash, as high as you can. Zip-tie it in and take a trip around the block on the trailer to test. I am not exactly sure where the one on my AT/C is mounted, but it is inside somewhere, and I have NEVER had a problem locating/tracking satellites.
Sydwayz is offline
Old 03-07-2005 | 04:55 PM
Raypanic's Avatar
I put mine under the dash on my Fountain it works plenty good enough, I did notice a slight decrease in signal only like 10% but it works fine. I also put the black one on my PQ on the surface. I painted it white first with no problems.
Ray
Raypanic is offline
