TRS question...
Old 03-31-2005 | 10:24 PM
  #31
J-Bonz's Avatar
Default Re: TRS question...
I would not buy a 90 to 95 boat that had bravos, they = junk
i fixed to many of them in that year range. especialy ones that have not been apart aka. time bomb
As for Trs
Just check the Lower pinion for pitting and case hardening wear every two years and enjoy reliability!
J-Bonz is offline
Old 03-31-2005 | 11:08 PM
  #32
Talking Re: TRS question...
Come on you guys, TRS is yesterday's news. Any more than 525 HP and you're on borrowed time. Put on a pair of 4 blade Bravo 1 props and you'll wear out the TRS gears in short order.
That smooth shift comes with too high a price. A very heavy hydraulic transmission that steals 25 HP from the prop AND pushes the two heaviest things in the boat forward 18 inches! Even a Top Gun with TRS is a MF to work on. Where do you stand? Ever change a bilge pump or float switch?
The Bravo drive has much better hydro dynamics and is lighter in weight. If you have one that shifts too hard, you probably need a shift cable adjustment. If you MUST have a sissy shift, then install the Power Shifters available.
Of course the early Bravos were worse than they are now. Testing them for five years in Lake X was a waste of time. Test those puppies out in the ocean where they belong. I can make an Alpha live forever in Lake X!!
Edward R. Cozzi is offline
Old 04-01-2005 | 07:52 PM
  #33
J-Bonz's Avatar
"Of course the early Bravos were worse than they are now. Testing them for five years in Lake X was a waste of time. Test those puppies out in the ocean where they belong. I can make an Alpha live forever in Lake X!!"
TOTALY AGREE WITH U, THATS THE BEST WAY IT WAS EVER PUT
if i was buying a new boat with hp up to 525hp, i would definately go with bravos. Otherwise speedmasters.
I do agree bravos = faster and lighter but, on lake erie a heavier boat = into smoother ride in the rough. Thats more important to us than top speed. Second, i have passed many new boats with hp 500 w/ bravos on the lake in the rough. our old mistress takes the rough like a tank. Infact the rougher ther better. I atrribute this to the weight of the boat plus the trs and transmission since it moves the CG forward wich keeps the bow down. if i was looking for a early 90's boat i wouldnt rule out going with trs's.
J-Bonz is offline
Old 04-01-2005 | 09:40 PM
  #34
I see your point, but you can give it a little tab and still keep your running attitude so that your ride is better.
Old 04-01-2005 | 10:43 PM
  #35
I say get the boat before the wife changes her mind !!! As for the TRS drive, do not run more than a 3 blade prop and they will out last the Bravo x 5 !!! I have seen as many as 600 Hrs. with 550 Hp. a side on my 30 Velocity in the 18 years I have owned it !!!! The boat will be better balanced than a Bravo boat as well !!!
steelintime is offline
Old 04-02-2005 | 03:34 PM
  #36
DannyD's Avatar
I would buy another TRS Boat. I owned two of them. Seas off the Jersey shore can get really rough. I too have a Mistress and I never really have to run a lot of Tab which is nice. I like the comfortable ride.
DannyD is offline
BDiggity
Drives and Lower Units
11
09-28-2008 12:31 PM
greg bakker
07-10-2007 12:08 PM
djtalon
1
05-07-2006 06:37 PM
Poorsche
13
04-15-2004 09:26 PM
cartman
11
06-10-2003 12:04 AM
