Blowers And Carbs-should I >
Old 04-26-2005 | 08:32 AM
fastlane40's Avatar
Question Blowers And Carbs-should I
In the process of building a 540/871 combo.I am hoping to use 2 Quadrajet carbs from 365 mags.The norm i know is 2 750 holleys.Will the skinny primaries and bowl size be a problem?I plan on a dyno run but was hoping someone out there might have already been there.
fastlane40 is offline
Old 04-26-2005 | 08:40 AM
dykstra's Avatar
Default Re: Blowers And Carbs-should I
Go with the Holley's. Just my 2 cents.
dykstra is offline
Old 04-26-2005 | 10:14 AM
If you're using them to save money, consider the time/money/effort to boost reference, correctlt jet, fabricate a way to mount them, and fabricate a throttle linkage. And hope while you're trying to set this up that you dont burn up an engine.
Gary
Gary Anderson is offline
Old 04-26-2005 | 10:39 AM
crazy canuck's Avatar
Don't mess around with the Q-jets .I've learned from the past building my hot rods buy the proper stuff now cheaper in the long run.
crazy canuck is offline
Old 04-26-2005 | 11:02 AM
Brad Zastrow's Avatar
Holleys only. I am not sure if twin 750's will be enough with that setup. Do your homework or you will smoke the engines. Blower motors need a lot of fuel to live.
Brad Zastrow is offline
Old 04-26-2005 | 04:36 PM
Strip Poker 388's Avatar
Rob
I would think it would need at least 850 with a 540.Barry grant has some reasonable carbs now and you can get them boost referenced already.I ran 2 gold claws 775 that flows 925cfm same blower and on a 460ci and made 762hp at 1 to 1 on the blower .
Pm ..Rum Runner he works for Barry grant ,he will shoot ya straight
Do not try to use the quads . Please
Strip Poker 388 is offline
Old 04-27-2005 | 08:14 AM
fastlane40's Avatar
Looks like the quad go in the bin.Anybody got any 750's?
Old 04-27-2005 | 10:03 AM
I still think 750's will be too small. You may need to be closer to 950-1000cfm ea. 540 CI and a 8:71 is big blower setup that needs fuel. Ask Dean Nickerson or some of the other experts. Holley may even have a tech line to call.
Old 04-27-2005 | 11:05 AM
Rob
Becarfull Your going to get idiots at Holley tech
JoeD
4
05-21-2008 07:26 PM
redcorvetteman3
2
05-15-2008 11:46 AM
merlin
Wanted
9
02-03-2008 10:30 AM
Donzi Black Widow
12
11-02-2004 12:02 AM
cobra marty
07-11-2002 02:00 AM
