Raising your X....
Originally Posted by z.zuperboat
Sounds like to much work to raise the X. Spend the money on some new 5 or 6 blade hydromotives!
..................doug
Originally Posted by KAAMA
But did you still see any gains by adding the -2" shortie???
My propshaft is 5.25" below the keel with the shortie.
According to Throttle Up, I could pick up another 3 mph if I went up one more inch.
Originally Posted by dyno
Can you raise your X dimension with out having to glass in the transom and start over? Whats the job take? raise the engine motor mounts and the drives..... I have off shore Gil mounts are they a biotch to move? I was told I can get several MPH on my 94 Sonic if I raise my "X" 2 inches and run 4 blade props.....
is your boat a 26 prowler?
i put a 2 " shortie on one and picked up almost 6 m.p.h., overthe stock case. i slao put one on a 27 activator, along with 6 blade herring and it too picked up significantly.i would say leave the transom alone , use the shortie, lower engine hieght translates into better C.G .
Imco sells an extension box that wil raise your x by three inches with the same transom hole. You will need to raise the engine though. 12" setback also.
Have fun.
Have fun.
