Roller lifters input >
Old 05-08-2005 | 07:58 PM
  #111
Johnny DCB's Avatar
Default Re: Roller lifters input
Originally Posted by GPM
I didn't care for the Pro 1s, they seemed a little light for a blower application.
You go with Brodix?
Johnny DCB is offline
Old 05-08-2005 | 08:06 PM
  #112
GPM
Originally Posted by Johnny DCB
You go with Brodix?
I ran the Pro1 for one season in a N/A motor,lost guides and head gaskets. Gaskets could have been my fault. Switched to the Brodix, I've run them 5 seasons now. I haven't lost a guide, or a gasket. Some people love the Pro1s.
GPM is offline
Old 05-08-2005 | 09:20 PM
  #113
Johnny DCB's Avatar
My original plan was too use the AFR 357cnc's but they were all of of stock on them and I thought this project was gonna move along faster than it has been.I'll put some thought into it but for now I'll stick with the Pro1's.Looks like CMI will be taking 6-8 weeks to build the headers,thats not a good thing to hear but what can I do.I need them.
I need to learn more about what lifters right now though.Im guessing I will need a centered large bore lifter for my Dart Big M block?Not the offset ones.Will any .903-.937 lifter work in a Big M block,with the right machining?
Old 05-08-2005 | 10:36 PM
  #114
GPM
I've been runnung the stock .842, 3 seasons with no trouble. I waited 6 months for the 357s and gave up. You might want to look at the new BB3 xtra CNC.
GPM is offline
Old 05-08-2005 | 10:51 PM
  #115
Johnny DCB's Avatar
I agree,the Brodix might be a better head for my motor.if I dont get the results I want or if I crack and port,Ill be Brodix shopping soon.
I need to find a deal on Jesel lifter right now.Easier said then done though.
Old 05-09-2005 | 04:54 AM
  #116
Mr Gadgets's Avatar
Charter Member #601
Thanks GPM! sounds like a good solution to my situation..
Mr Gadgets is offline
Old 05-09-2005 | 08:59 AM
  #117
I would go with the Manton or Smith Bros. 2 piece tapered pushrods. This way you can tune each pushrod to the proper length.
Chris
cstraub is offline
Old 05-09-2005 | 06:06 PM
  #118
Johnny DCB's Avatar
Chris
Good advice,thank you I'll keep this in mind when the time comes.
Old 05-09-2005 | 08:05 PM
  #119
Mr Gadgets's Avatar
Charter Member #601
I called CV and Manton today. I am going to try and use a straight 7/16" push rod, per Manton's suggestion. I am using guide plates, so the tappered ones are not an option as I was told. Next set of heads get the T&D's. For now trying to stay with what I have. If the 7/16" dont fit, then I will use the .135" wall from CV. They have a faster lead time than Manton. I picked up a 7/16" dowel today. When I get it mocked up, I can tell better which way may work. Hey, I could make them out of wood.. maybe that would work?/
Thanks for all the good info guys.. I believe I am headed in the right direction..
Dick
Old 05-09-2005 | 09:08 PM
  #120
GPM
Mr G, how much spring pressure are you running?
GPM is offline
