Power Steering squeals >
Old 05-01-2005 | 07:12 PM
ctadams21's Avatar
Default Power Steering squeals
When I first fire up my starboard motor, the power steering squeals very loudly. If I let it idle it will suddenly stop after a short while as if it instantly fixed itself. If I rev the throttle a bit I can also get it to stop.
Is this just the belt or do I have other problems?
The tension on the belt seems o.k.
CTA
ctadams21 is offline
Old 05-01-2005 | 07:32 PM
offthefront's Avatar
Default Re: Power Steering squeals
belt
offthefront is offline
Old 05-01-2005 | 10:16 PM
If it's Merc Racing engine, the serpentine belt needs to be set pretty tight, but at idle the pressure in the system should be low if not turning the wheel. If there is a filter, check it or even temporarily remove it. If these things don't help, check for some other type of restriction, possibly a hose that might have separated internally. Hope you find the problem.
Falcon is offline
electrical1
6
06-11-2006 08:29 PM
florida gator
1
04-13-2003 06:57 PM
CHAOS REIGNS
5
12-11-2002 07:56 PM
SeaWeasel
2
08-12-2002 09:29 AM
waden54
2
06-30-2002 08:23 PM
