How accurate are GAFFRIG SPEEDO'S
Originally Posted by craig223
the speedo is dead on until 60 mph, then it exagerate's like it's been drinking all day!!! About 4 mph over gps readings at top end.
Charter Member #40
Overall GPS is a much more accurate way to go. If you are in an area with some tidal speed then you need to run with and against the tide for an average as gps is speed over ground. If you have Livorsi actually take your water speedo and specifically calibrate it at a certain speed range I think you will find it can be very accurate. However, they seem to change after a couple years and need to go back. I use the spring loaded deal and I still bend pickups. Personally, I like the water speedo as it is instantaneous but then I also look at the GPS just to be sure.
mcprodesign
Fountain
16
05-13-2008 03:46 PM
SHAKEN Not Stirred
29
06-26-2003 01:05 PM
