TRS Rebuild Kit? >
TRS Rebuild Kit?
TRS Rebuild Kit?
Old 06-10-2005 | 11:22 AM
Mbam's Avatar
Offshoreonly Advertiser
Default Re: TRS Rebuild Kit?
We have them in stock - see:
http://www.mercruiserparts.com/Show_...SING+%28TRS%29
Mbam is offline
Old 06-10-2005 | 05:30 PM
BBB
I used alluminun spool gun with 100% argon, got good pen. reshaped weld to match surface. wish I had a TIG but ya got ta go with whacha got. I can see where the rear of the housing takes a lot of load. just keeping fingers crossed. let you all know monday if it holds. if not......hello, BAM ?
BBB is offline
Old 06-14-2005 | 05:01 PM
Bowmann's in houston does alot of props, but they also have been know to do welds on drive casings, I'm going to take mine by and see what they can do, I'll let you know how things turn out.
spk1 is offline
Old 06-15-2005 | 11:27 AM
BBB
test drove ( welded lower ) weld held ! Ya hoo, but while I was out the other drive puked all over inside the engine bay, out the resevoir, turned out the oil transfer hose from the bell housing to the transom had a crack and allowed water into the drive, pulled drive and bellow, replaced 3/8 hose yesterday. lots of fun installing these drives by you're self.
BBB is offline
Old 07-13-2005 | 11:18 PM
Poorsche's Avatar
I've got four drives that got the electrolysis cancer. Does it makes sense to buy new upper and lower cases and rebiuld or just try and sell the parts?
I'm told all the shafts and gears are good--bearings probably good--just "housings" are bad.
Any thoughts?
Poorsche is offline
CAPTAIN CHUCK
9
07-03-2008 05:43 AM
ctuck0659
3
04-03-2006 08:50 AM
375stinger
7
11-28-2005 08:07 PM
Waterboy123
6
10-15-2004 02:59 PM
MrCIG
2
05-13-2002 11:35 PM
