Adjusting Gaffrig Mechanical Indicators >
Old 06-14-2005 | 06:51 PM
Dave M's Avatar
Veteran: Navy
Default Adjusting Gaffrig Mechanical Indicators
Any good tips on adjusting indicators? My tab indicators are not even(maybe 1/4" off). They work but it just bugs me. The doesn't seem to be too much room for adjustment on the cable ends
Also my trim indicator seems to have some play in it. I can pull down on the cable at the the drive and I have about 1/2 inch of play.
Dave M is offline
Old 06-15-2005 | 07:37 AM
BillR's Avatar
OSO Moderator
Default Re: Adjusting Gaffrig Mechanical Indicators
You adjust them at tabs. There are threads and a lock nut for fine adjustment.
With a straight edge on the bottom of the boat make the tab level with the bottom of the boat. Pick a number to adjust them up both the same on the indicator gage and then mark the indicator gage. Use adjustment on cable at tabs to even up indicator on the dash.
Real easy!!!
As far as play, Most MFG's don't install the springs that keep tension on the indicator on the dash display. Livorsi sells springs for these and are easy to install. Takes the play right out.
Also Merc indicators have the same springs available. Look here for a breakdown of parts:
http://www.mercruiserparts.com/Show_...+%284+CABLE%29
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
Old 06-15-2005 | 07:45 AM
Dave M's Avatar
Veteran: Navy
Thanks! You're right about the springs, I don't have them on mine.
Dave M is offline
bigmotor
2
08-11-2008 07:39 PM
253checkmate
Checkmate
7
03-26-2008 11:14 PM
Livorsi Marine
New Products and Member Discounts
1
09-05-2006 02:07 PM
offthefront
1
08-23-2004 12:47 AM
FBRONCO
5
04-30-2003 07:27 PM
