how to fill
Old 01-22-2006 | 08:05 PM
Default Re: how to fill
East coast B- if you just disconnected the lines at the pump then yes just cycle up and down a little and it will remove the air.Tommy just rember not to screw the filler plug all the way down.I keep mine so I can see the o ring above the threads of the fill hole.
FloridianSon is offline
Old 01-22-2006 | 08:13 PM
East Coast B's Avatar
OK, so I operate it up and down to get the air out... AND... the dip stick doesn't get screwed in all the way tight.. correct??? Keep the dip stick loose so the air can escape?? Thanks for your help, REALLY appreciate it!
East Coast B is offline
Old 01-23-2006 | 01:10 AM
GOODT's Avatar
it is self bleeding, if you disconnect the line to bleed unless you put them in a bottle with fluid in it you will suck air into the system, just hook everything up and cycle up and down holding for a min at the end of each cycle
GOODT is offline
Old 01-23-2006 | 07:03 AM
Thanks GoodT!!!
hunster
04-23-2008 06:42 AM
klaw
05-16-2007 06:34 PM
JasonSmith
Detailing, Painting, & Fiberglass
1
02-21-2006 08:08 PM
yesrej
3
06-04-2004 08:57 AM
