Engine Removal on TRS >
Old 07-05-2005 | 10:19 PM
VelocityMike's Avatar
Default Engine Removal on TRS
Hey guys wanted to know how hard it is to remove a 454 330hp without removing the drive and trans. Any help would be great!!!!
VelocityMike is offline
Old 07-05-2005 | 11:44 PM
tcelano's Avatar
Default Re: Engine Removal on TRS
There is a whole thread on the pros and cons of removing the transmission or not. Either way, you can have it out in a couple hours. Some boats get a little tricky due to having to remove accessories. Mine is a puzzle...
Basically it boils down to disconnecting fuel, electrics, water, and oil, taking some tension with the lift, and unbolting the mounts and bellhousing bolts. Slide the motor forward about 1.5" to disengage the flexplate splines, do some fancy angling and pull it out. Honestly, I think it's way easier to pull it with the transmission still attached, but that's me (SSM III setup). I also vastly prefer fitting up the bellhousing and tranny out of the boat. If you are using a new motor block or bellhousing, it pays to check the runout before bolting it all together.
It's worth pulling the drive to check alignment if it hasn't been done in a while. If your engine compartment is restricted lengthwise, it will also help you by not having to push the motor forward or angle it up quite as much to disengage the tailstock from the drive input shaft.
tcelano is offline
Old 07-06-2005 | 12:50 AM
Lofty's Avatar
It's only six nuts, the rams and some steering! You can't be serious?!?!?! Just pull the drives! Doing it any other way is a waste of time. When it comes time to re-fit it'll be so easy with the trany's out.
Lofty is offline
Old 07-06-2005 | 05:05 AM
David's Avatar
Pull the drive first. You need to check alignment when you put the engine back in, anyway.
David is offline
Sea Rat
Powerplay
5
12-07-2007 07:12 PM
formula24
Drives and Lower Units
4
07-07-2007 10:38 PM
Dangerous Dave
0
10-06-2006 03:53 PM
MILD THUNDER
8
11-10-2005 01:23 PM
robert johnson
3
01-21-2004 08:46 PM
