Marine Lubrication
#1641
It was my understanding that the oil companys had to lower the amount of zinc because of EPA regs. (Catalytic converters) I think GM had a cam break in additve, but I'm not sure if it's still available. JC gave me several Oil options. Doug
#1642
[QUOTE=outriggers;2894340]
If you are going to use Mobil 1 V-Twin, there is more than enough.
Stay away from conventional automotive products.
Motorcycle specfic products do not fall under the zinc reducing policies of the major oil companies.
Ken
Waste of money.
You have to give me more than that. It seems ZDDP is a factor in the quality of the oil. Are you saying there is already enough in the off the shelf oils? http://www.cam-shield.com/index.html Doug
Ken
#1643
[QUOTE=minxguy;2894844]
SM oils have very low ZDDP.
You NEED an SG; SH..SL... oil. If it says SM; SL; SG then don't use it. SM oils have only 800 ppm zinc whereas V-Twin for example has 1600 ppm.
M-1 Silvercap/Amsoil 20W-50's/M-1 V-Twin/Redline/ Motul/RP... etc are all great.
#1645
[QUOTE=Hydrocruiser;2895023]
I ran the M-1 20/50 V-Twin in my ZZ502 for 4 seasons, with plenty of hard run time. The engine was torn down at about 140 hours and the builder said the internals looked great. So I'm a believer in the V-Twin.
The ZZ502 is now a "ZZ557" with about 200 more HP than before. The M1-V-Twin is a PIA to find. Would the Mobile 1 silver cap in 15/50 be a good choice/substitute? I change oil/filter every +,-20 hrs.
#1648
Is that all they had? I would have purchased every last bottle!!
Put your best foot forward!
#1649
there was 23 or 24 qts available. I wouldn't spend the $10 qt. to fill out 18 for a second change of it, happy with the $5 qt. "regular" M1 20/50.
but at $2 a qt the 18 qts I did take saved me money on the next change over the reg. 20/50 at wallyworld!
can't beat that!!
can't beat that!!
#1650
[QUOTE=Kidnova;2897665]
I run the Amsoil in my Bravo 1 drive as well as my engine (500EFI).
I run this in my engine:
http://www.amsoil.com/storefront/wcf.aspx
This in my drive:
http://www.amsoil.com/storefront/agm.aspx
For the people who are looking for something a little thicker, this would be a good alternative as well:
http://www.amsoil.com/storefront/aro.aspx
If you're interested in purchasing the Amsoil, I'm a dealer and can get you a better price then you see.
This in my drive:
