Marine Lubrication >
Marine Lubrication
Marine Lubrication
Old 07-22-2009 | 10:12 PM
  #1661
2112's Avatar
V-twin is getting hard to find up here. One local distributor needs $12 per quart. Where are you finding it in bulk and approximately how much is going for?
2112 is offline
Old 07-22-2009 | 11:50 PM
  #1662
Rebel_Heart's Avatar
If I wanted to change from Valvoline VR1 40w and Wix Racing Filter, what do you recommend? I have a pair of 540s that are two years old. Would like to run the oil for the season, 25 hours. Maybe the Wix filter is ok? Thanks.
Rebel_Heart is offline
Old 07-23-2009 | 05:24 AM
  #1663
Originally Posted by bck
What about custom blend oils? Haven't seen any info on that. I have access to someone who says he does custom blends for people and has been doing it for years. What can these people do and what would the be the ideal oil if he could do whatever you wanted?
I wouldn't think you would see info on that.
Most people who want custom blended oils don't want the world to know what it is. A sample of the oil and an analysis of the sample will put you into the formula though.
I would guess if you are running an Indy car and needed a "real special" tranny oil with additional anti-wear, say moly instead of the more conventional stuff and a real thin synthetic base stock you would have to go custom blending.
In the real world, I can't see any advantage. Products on todays shelves are the best they have ever been, sure you can debate the zinc levels, TBN numbers, drain intervals, etc
but when was the last time someone used a ridge reamer to remove pistons? It was common practice to stay away from an engine with 100,000 miles, now we are wearing our cars milage as a badge of honor. Sure machining and metalurgy have all become better, but so has the oil.
Custom blends, not practical fo Joe consumer in my opinon.
Just my 2 cents.
Ken
minxguy is offline
Old 07-23-2009 | 07:05 AM
  #1664
I'd use the AMSOIL Dominator 15w-50 Racing Oil. The Wix filter will be fine.
07DominatorSS is offline
Old 07-24-2009 | 05:38 PM
  #1665
Hydrocruiser's Avatar
Arrow
That's what " 2000 lb Gorilla Oil" can cost these days...and yes...it can be worth it.....especially in the big expensive engines like Merc's 700- 1050's..
If you can't find it...then this is "equivalent" from Amsoil and very easy to get. If you get an associate membership (cost of $10.00.. it will allow 20% off your purchases for six months".
With the 20% discount (in gallons with discount) final price is $ 8.43/qt...that's a deal.
Both V-Twin and Amsoil Motorcycle Oil have outstanding anti-rust properties...this allows storage for extended periods without fogging..incase you forget of course.
http://www.amsoil.com/storefront/mcv.aspx
Hydrocruiser is offline
Old 07-24-2009 | 05:49 PM
  #1666
Arrow
We need to get an oil analysis on this newer oil...see what's in it...
Old 07-24-2009 | 07:24 PM
  #1667
2112's Avatar
That is a big price difference for the same product. What is up with Mobil 1? Meaning, why so hard to find nowadays?
2112 is offline
Old 07-24-2009 | 07:51 PM
  #1668
2112's Avatar
Do you know how to tell what the shelf life is? If you bought a 30 gallon drum, how fast would you need to use it before it goes bad?
2112 is offline
Old 07-24-2009 | 09:46 PM
  #1669
Arrow
Mobil just "reformulated" M-1 10W-40 MX4T Motorcycle and now it's called Racing 4T.
(Reformulations can sometimes be another word for replacing a base oil that is not as costly).
It's possible that as MX4Twas reformulated...V-Twin may be next in line.
Old 07-24-2009 | 09:52 PM
  #1670
Arrow
I asked that question of the owner of a "15 minute" Quaker State" oil change center. Lots of 55 gallon drums of oil ..pressure dispensing equiptment hooked up...basically a "sealed" system.
How long does the manufacturer say it's good for?
Response..
Must avoid humidity and temperature changes that might cause condensation. That being said...I was told a couple 2-3 yrs.
