Marine Lubrication >
Marine Lubrication
Marine Lubrication
Old 08-18-2005 | 09:14 PM
  #221
Hydrocruiser's Avatar
Arrow Re: Marine Lubrication
Originally Posted by Kidnova
vandy,
The price dump is appreciated. I was going to pm you about getting the VT from you. But seeing that I get oil in a small quantity {single BB and maybe about 35-40 hrs. per season} I did'nt think it would be worth the effort on your end.
What's the word on the V-Twin 10-40? I know a guy that is looking for the benefits of the V Twin 20-50, but in a lower viscosity. His oil pressure is on the high side, so he does'nt want to go with 20-50. Would the V Twin 10-40 be a good substitute? And would it help with oil temps as the 20-50 does?
I am not one to really condone mixing as who knows what you really get in the end. If the pressure is too high on 20W-50 use the 15W-50 Goldcap.
Hydrocruiser is offline
Old 08-18-2005 | 09:15 PM
  #222
Hydro - That is good news about the bearing temp possibly being so much lower.
Another thing I was concerned about were seals in the engine. I was told that getting over 240* could cause damage there.
I have not heard anything about this.
Old 08-19-2005 | 02:08 PM
  #223
vandy021's Avatar
Default Re: Marine Lubrication
I would go with the Gold Cap 15w50. I am not too familiar with the 10w40. We don't have many requests for the 10w40. Kindanova, if you want, I can get you an XOM distributor in your area. Just let me know. NY is out of my area of best effort, but I will do what I can. I have gotten several OSOers hooked up with XOM distributors.
GOOD LUCK!
vandy021 is offline
Old 08-19-2005 | 09:47 PM
  #224
Vandy, I have a distributor about 20 mi. from me but thanks.
I was asking about the V-Twin 10-40 on behalf of a guy in Maryland. I suggested that he read the info in this thread, as he is the one with the high oil pressure.
He's a big boy and all growed up so it's up to him now
Kidnova is offline
Old 08-19-2005 | 09:56 PM
  #225
What's his oil pressure anyways? Everything can be relative. Also need to know what oil filter he is running.
Old 08-20-2005 | 07:58 PM
  #226
http://www.kendallmotoroil.com/Products/Gear.htm
You can now see that Kendall is offering a Fully Synthetic Gear Lube 80W-90. It has a GL-5 rating and excellent additive package including anti-corrosion additives. It is a PAO based product and would be SIMULAR in base structure to Amsoil and Mobil in that respect.
Kendall also has added a Fully synthetic 5W-30 and 10W-30. They do not have a 20W-50 Synthetic yet.
I was asked what I would use and from the data I have reviewed my answer would be Royal Purple; Mobil-1; Kendall; Redline; Torco; Amsoil or Mercury HP.
Redline has an ester base and tons of HP additives. It has my attention and I would like more feedback on it regarding performance and any foaming issues.
It's hard to miss using any of these outstanding products.
Old 08-22-2005 | 05:20 PM
  #227
I hear M-1 0W-20 buy 3 get 3 free at PepBoys....who knows..
Old 08-24-2005 | 01:38 PM
  #228
I was asked what syn oils have a ZDDP level greater than .2
Answer:
Synergyn, M1 Racing, M1 motorcycle oils and Torco.
Old 08-25-2005 | 09:15 AM
  #229
On engine oil temps: (perhaps this was touched on earlier and I missed it) I was told that operating oil temps. above 220* (so that combustion moisture will be vaporized) but below 280* were acceptable for conventional oils and that synthetics could handle even higher temps. for longer periods. Anyone have any really reliable info. on this? --- Jer
jpclear is offline
Old 08-25-2005 | 10:47 AM
  #230
vandy021's Avatar
The moisture is combusted, but there isn't the level of oxidation like in an industrial application. Syns do handle higher temps for longer periods. The molecules are synthetic polymers which don't fall out as quick as a conventional oil. Mobil states "that the Mobil 1 is suitable for high-performance cars, particularly hot-running or heavily loaded vehicles."
Normally you will see a decrease in oil temperature and a decrease in pressure during idle. Sometimes you will see a higher HP at high revs due to the viscosity increase.
vandy021 is offline
