Drive Res. Sensors? >
Drive Res. Sensors?
Drive Res. Sensors?
Old 08-17-2005 | 03:59 PM
29KILROY's Avatar
Default Drive Res. Sensors?
On a 2000 454mag efi can you run with the Drive Res. Sensors unplugged? if so both or one wires, if not can you buy pass them if needed. I looks like it just completes a ground when it bottoms out setting off the alarm.
29KILROY is offline
Old 08-17-2005 | 04:36 PM
hillbilly24's Avatar
Default Re: Drive Res. Sensors?
If you are haveing problems with the sensor you can run with it unhooked, you can unhook one or both of the wires and just tape over the ends for a temporary fix. The switch just makes a connection when it bottoms out. The reason they ussualy fail is becuase people don't clean the resevoir out during a drive service. Alot of parafin builds up if you run merc oil and the float becomes unable to move. Sometimes they just fail though either way yare fine to run with it unhooked just keep an eyes on the drive lube level.
hillbilly24 is offline
Old 08-18-2005 | 06:21 AM
29KILROY's Avatar
Thanks Hillybillly. I clean mine every time but one of them is pissing me off now....Also, thanks for all your other replies to other peoples posts!!! It helps us all learn, you know the saying your never to old to learn!
29KILROY is offline
Plane Silly
Drives and Lower Units
4
09-08-2008 12:21 AM
glassdave
05-22-2008 11:37 PM
Bryan Rose
2
05-18-2008 03:16 PM
25Daytona
Poker Runs and Boating Events
58
10-19-2004 06:49 AM
jcap
4
07-05-2003 12:03 PM
