??? lost power trim power again >
Old 08-27-2005 | 04:42 AM
Default ??? lost power trim power again
I lost power to my power trim on tuesday, turned out it was in line fuse by the battery switch. I went to go out last night, no power trim again. What could be causing it to blow? Both times it seemed to happen when the dirve was all the way up in trailer mode. ( It didn't go out while raising the drive) But when I went to lower it back down on the next outing.
Has anyone experienced this before?
thanks
jc
jcimprover is offline
Old 08-27-2005 | 07:57 AM
Brad Zastrow's Avatar
Default Re: ??? lost power trim power again
Yes, when I had a bad pump motor.
Brad Zastrow is offline
Old 08-28-2005 | 09:52 AM
GOODT's Avatar
More then likly brad is rightbut you might want to check the connections at the pump first!
GOODT is offline
Old 08-28-2005 | 07:56 PM
Changed the 25 amp fuse (blew 4 of them) put a 35 amp in, it worked fine all day. Could the pump be on its way out? (why its needing more juice to run it?
JC
twin242ls
06-06-2007 11:34 AM
twin242ls
3
06-06-2007 05:44 AM
norton
29
11-29-2006 11:29 AM
DustinM
07-19-2005 09:02 PM
MACTIME
03-22-2005 04:02 PM
