fuel pump recomendations ? >
Old 08-29-2005 | 07:46 PM
Default Re: fuel pump recomendations ?
Originally Posted by HigherPower
I had a Holley pump at first. It lasted maybe a total of 6 hours. I bought this Carter about 3 seasons ago. I have put about 125 hours on it. It still pumps, but is weak, shows 3 psi on gauge.
Well I have over 100 hours on my Holley's, still pumping very strong regulated down to 6 lbs, but they are mounted lower then the tank they are always wet!! (with fuel). that may help!!
P.S. I would run 1/2 iinch lines now because if you are like the rest of us boaters you will add more power sooner than later!! goes with the territory
abones is offline
Old 08-30-2005 | 07:16 AM
I use the weldon 600 pump. I only have about 80 hours on it so far, but it has worked perfectly. Runs silently and weldon said that they have one on a test stand that has been running for over 2000 hours continuously with no problems. It looks good too. On one side it has some Japanese writing on it, I asked what it said and they told me "made in America". Not bad pricing either, about 375.
Nova 26 is offline
Old 08-30-2005 | 08:18 AM
Donman's Avatar
Where do you buy Weldon pumps?
What are the specs for the 600 model?
Donman is offline
Old 08-30-2005 | 10:36 AM
ratman's Avatar
summit racing has a 150gph aeromotive for 165.00 its a great pump no bypass needed just a good regulator. heres the link most bang for the buck
aeromotive pump
ratman is offline
Old 08-30-2005 | 10:40 AM
Call Fred At Trick And Get A Cv Marine Pump Its About 400.00 But Its Well Worth It 8psi And All The Fuel You Can Use
rocket ronnie is offline
Old 08-30-2005 | 11:10 AM
Weldon, Weldon, Weldon, Weldon. Once you buy one you'll understand.
Chris
cstraub is offline
Old 08-30-2005 | 12:39 PM
Official OSO boat whore
Having the fuel pump below the fuel level is a requirement for these pumps to live. They simply are not able suck the fuel up out of the tank. The problem is that mounting them low like this is very clearly a Coast Guard violation. You can not create a situation where the fuel will have an opportunity to siphon out. Having the pump low in the bilge creates this situation. The best solution would be to mount the pump in the tank. Aeromotive might have a in-tank pump, but I'm not certain.
Cord is offline
Old 08-30-2005 | 01:58 PM
Wobble's Avatar
SORE MEMBER
I run a holley black marine with a return style log with built in regulator. This allows any excess fuel to return to the tank. Has worked great for 3 seasons. delivers 5 gallons in 2 minutes 20 seconds at carb height. Pump mounted in bilge.
Dead head regulators seem to kill electric pumps in short order and dramatically reduce their fuel delivery rates.
I am using a gaffrig fuel pressure sender and guage.
Wobble is offline
Old 08-30-2005 | 02:31 PM
Been using a Holley Black for two seasons with no trouble. With the rep of Holley I suspect I have been lucky thus far. I plan on replacing it this winter as part of PM. Anyone using the Aeromotive SS?
http://216.242.145.16/products/product.phtml?p=7
Should be a good product.
BadDog is offline
Old 08-30-2005 | 02:42 PM
Wobble's Avatar
SORE MEMBER
A buddy put one on his jet boat, lasted about 16hours. They did repair at no charge however.
Wobble is offline
