fuel pump recomendations ?
put on Holley reds at the beginning of the season and have about 20 hours on them no issues yet.
If your boat has a sail do you ride a horse to the ramp?
I may be wrong, but as I recall, the weldon 600 can be mounted "above the fuel tank without concern" according to weldon. I bought mine from Kinsler fuel injection in Michigan. It does need a bypass regulator though or it will run the pressure up to about 250 psi if deadheaded.
Originally Posted by HigherPower
I need to replace my failed Carter electric pump.
Single Holley double-pumper, single engine (about 500 hp), Max RPM 5800.
What do you guys recomend?
I`m thinking that I`ll upgrade all lines to 1/2" and install a regulator for sure.
I`d also like to possibly install a fuel psi gauge on my dash, anyone done this?
Thanks for all replies!
I routinely use mallory marine pump's, sometimes regulated, most of the time the 9 psi pump with a regulator. more affordable than the weldon, wich is a great pump but for higher hp applications and they do make some noise.Aeromotive is also good but stioll a lil pricey, and your not making much power. -10 line from tank to pump. -8 from pump to carb. this reduces aeration and high fuel temps from using small diameter fuel line. always use radiused 90's, not machined.
good luck
I Sell A Pierburg That Will Work Just Fine. It Will Need A Regulator And A Return Line To The Tank.i Have Dozens In Use And Have Had No Problems.you Can Get One For About $186.00. You Can Call Me
Jim At Fluid Systems 586-790-8880
BillR
11
07-29-2022 06:31 AM
BillR
27
08-10-2008 11:31 PM
Rage
6
07-31-2007 09:45 AM
