fuel pump recomendations ? >
Old 08-29-2005 | 08:58 AM
Donman's Avatar
Default fuel pump recomendations ?
I need to replace my failed Carter electric pump.
Single Holley double-pumper, single engine (about 500 hp), Max RPM 5800.
What do you guys recomend?
I`m thinking that I`ll upgrade all lines to 1/2" and install a regulator for sure.
I`d also like to possibly install a fuel psi gauge on my dash, anyone done this?
Thanks for all replies!
Donman is offline
Old 08-29-2005 | 11:13 AM
kaama82's Avatar
Default Re: fuel pump recomendations ?
500 h.p. don't waste your money on 1/2" line unless you plan to go bigger in the future.
kaama82 is offline
Old 08-29-2005 | 11:32 AM
velocitypwrbtr's Avatar
Wink Re: fuel pump recomendations ?
Just bought one.
http://store.summitracing.com/defaul...=egnsearch.asp
velocitypwrbtr is offline
Old 08-29-2005 | 11:58 AM
Official OSO boat whore
I ran twin Mallory marine pumps on my cat. They were wired alternatly so only one pump ran at a time. After around 50 hours of use, both pumps were showing signs of failure. This is pretty consistent with other members experience with electric fuel pumps. These things just do not live. As much as I hated the extended crank times with a mechanical pump, I'm thinking that is the way to go. Perhaps a check valve could be added to prevent the fuel from draining back.
Cord is offline
Old 08-29-2005 | 01:53 PM
My Holley's didn't even last that
Old 08-29-2005 | 02:54 PM
Donman's Avatar
I had a Holley pump at first. It lasted maybe a total of 6 hours. I bought this Carter about 3 seasons ago. I have put about 125 hours on it. It still pumps, but is weak, shows 3 psi on gauge.
Donman is offline
Old 08-29-2005 | 05:01 PM
Registered User
After two Holleys I went to an Aeromotive marine pump with a bypass regulator. The bypass was an extra hassle to set-up. Should have the boat out this weekend.
excalibur81 is offline
Old 08-29-2005 | 05:37 PM
Donman's Avatar
Where did you buy the Aeromotive? ...and how much $$$ did it cost?
Donman is offline
Old 08-29-2005 | 06:06 PM
Registered User
REX Marine had the pump and regulator. Bonaco.com made up the stainless lines for the regulator.
Old 08-29-2005 | 06:07 PM
Registered User
The whole thing was about 450 dollars.
