Bravo 1 slip ? >
Bravo 1 slip ?
Bravo 1 slip ?
Old 09-06-2005 | 01:39 PM
Default Bravo 1 slip ?
I have a 22' Scarab with 454(310hp)/bravo1 with a 25p Mirage+ . The problem I seem to have is when im mid throttle, trimmed up alittle and go into a turn, the boat slows down alittle (maybe 5-10 mph) and the rpm stays the same. When I straighten it out it stays the same speed for 5 seconds then you can feel a slight thud then it starts accelerating again without any RPM change. Seems to only do it when I first take the boat out but after a few more trips around the lake it dont seem to do it anymore. The boat Holeshots and accelerates with no drama, only seems to be an initial turning issue.
Thanks for the help
Mike
Unitek is offline
Old 09-06-2005 | 01:44 PM
Default Re: Bravo 1 slip ?
I also want to add that the skag and the prop are in good shape. I also had the outdrive fluid changed to the Merc Hi-Po fluid ( non-synthetic). boat and outdrive has 128 hrs.
Mike
Unitek is offline
hoozeyurdaddy
Drives and Lower Units
3
11-23-2007 09:12 AM
ENFORCER24
15
03-20-2007 12:30 PM
docmanrich37
6
12-18-2006 11:04 AM
Bob280Silencer
Prop Talk
1
05-16-2005 06:52 PM
Scooter
02-04-2002 09:41 AM
