cam
Old 11-19-2005 | 03:18 PM
hondatv's Avatar
Default cam
Looking for some advice on how much cam overlap I can run with lightning thru hall ex. water jacketed.
And what is a good Dampner to run on a 540 bbc internal bal?
Which heads AFR 305s or 325s should I run on a 540, 9.5 to 1, single plane intake, 1050 carb, 2800 to 6000 rpm range 3700 cruise?
hondatv is offline
Old 11-20-2005 | 09:39 AM
KAAMA's Avatar
Default Re: cam
honda, There has been a TON of talk on this subject. Do a search and you'll have a lot of good reading. Also, "rmbuilder"/Bob Madera would be at least one good person to get ahold of concerning your head/cam, set-up/combination. He engineered my project, and did so for many others. He's also a man of integrity. Send him a PM if you're interested.
KAAMA is offline
Old 11-20-2005 | 06:16 PM
GPM
Default Re: cam
How much power do you want to make, and what is it going in?
GPM is offline
Old 11-20-2005 | 07:03 PM
hondatv's Avatar
Default Re: cam
It's in a 18ft jet tunnel hull.
I would like to make as much as I can, but reliablity is high on the list and I think the ex. is going to hold me back.
Does any one know if a 10qt stock rail oil pan will work with this set up?
I just sent rmbuiler an email.
I have read so much my head is spinning
hondatv is offline
Old 11-21-2005 | 08:04 PM
hondatv's Avatar
Default Re: cam
I'm still waiting to hear back from Bob.
I have picked up a lot of good info on this site so far and hope to get more.
Does anyone know of any good sites to find some good info for a jet boat?
hondatv is offline
Old 11-22-2005 | 07:08 PM
Default Re: cam
try: Hot Boat.com
tomcei is offline
Old 11-22-2005 | 07:17 PM
hondatv's Avatar
Talking Re: cam
Originally Posted by tomcei
try: Hot Boat.com
Thanks I will try that site.
Bob (rmbuilder) called today and he sounds like one knowledgable and is very helpfull person. Thanks KAAMA
hondatv is offline
Old 11-22-2005 | 09:22 PM
KAAMA's Avatar
Default Re: cam
I'm no expert, but I would think a stock 10 quart oil pan should work for you. I know some guys using the stock Merc 7 quart oil pans with 600+ hp engines without problems. Perhaps someone else can chime in on your oil pan here---or perhaps Bob may know or get you the correct answer.
Rmbuilder/Bob really knows his stuff....he'll get you zero'd in.
KAAMA is offline
Old 11-24-2005 | 06:29 PM
hondatv's Avatar
Default Re: oil pan
It's a 10qt Doolley pan, I forgot to ask Bob if it will fit. I'm talking about the pan rails fitting a stroker crank and rods. The pan rails are not notched for a stroker. I will be running a Callies 4.250 crank with Eagle H beam rods 6.385 and ARP2000 bolts.
hondatv is offline
Old 11-25-2005 | 10:36 AM
Default Re: cam
ATI seems to be the dampner of choice
i would use the 305's going to need alot more comp with the 325 unless your charging..
i built a 9.8 540 9/4/1/ canfield 310's , crane 731 cam, merlin single plane , holley 950hp, msd ignition.
made 560 peak hp at 5300
made 621 peak tourqe at 3700 - 600 thorugh 4200 rpm
this was full dress and stainless marine exhuast
numbers could be alot higher with dry header's. you would see a little bigger #'s with the lightning header.
the heads are a little too big and cam is a little small.
and i could use more comp. a solid 550hp is fine for my use
funny thing is others posted similar combos claiming wayyy bigger #'s. these are real...
open87 is offline
