Will 1" HVH Carb Spacers Help? >
Old 12-29-2005 | 01:00 PM
Default Re: Will 1" HVH Carb Spacers Help?
Brian,
Normally a bobble like that in the torque is due to the carburetor tuning. If you could e-mail me the complete dyno sheets I may able to point you in the right direction.
RumRunner is offline
Old 12-29-2005 | 04:05 PM
Baja, My motors picked up 2hp & 2lbs of tq. with the hmv supersucker. If for no other reason they make a good heat spacer. I did my tunning on a dyno. I try to get the most timming and hp with the lowest egt. I run 38 total timing on 93 octane. My egt runs in mid 1300 range. I agree with AUDICY, you can get more out of the boat by working with whats under the water line. I run two 540na chevys, 718hp@6300-668tq@5300 in a newer boat these motors would do a good job, but i have an old resin bucket that is very resistant to any modifications. Brian
scarrab30 is offline
littledcsrodshop
Swap Shop
1
08-30-2008 12:36 PM
BajaRunner
31
04-27-2006 01:17 PM
BajaRunner
4
03-02-2006 06:23 PM
TomR
12
01-02-2003 10:50 AM
Dean Ferry
05-15-2002 02:00 PM
