Mercruiser Engine Problem >
Old 01-10-2006 | 07:40 AM
  #41
Knot 4 Me's Avatar
Default Re: Mercruiser Engine Problem
As other's have already mentioned here, my first guess would be a weak fuel pump. Hook up a fuel pressure gauge and take it out so you can see what it is reading under a load. I recently had the same problem. Fuel pressure was 40+ PSI at idle and dropped down to about 17 PSI as I started to plane the boat out. Good luck! I agree that the IAC would be a very unlikely culprit, but stranger things have happened!! Also, check the fuel line from the tank to the fuel filter housing and make sure it has not developed a soft spot and is collapsing under load.
Knot 4 Me is offline
Old 01-10-2006 | 12:55 PM
  #42
mr_velocity's Avatar
My uncle had this problem 2 years ago, the Merc mechanic went through everything in the end it turned out to be plug wires. I'm still at a loss but the bad wires seemed to mess up the computer.
Last year the other motor started surging at idle, still haven't fixed that one.
If it were me I would be taking the advice the board has given and start swapping components from one motor to the other.
mr_velocity is offline
Old 01-10-2006 | 02:35 PM
  #43
formula31's Avatar
Originally Posted by GOODT
ok here we go first its not my boat read the post....
second, I dont survey boats I fix them....
third..... i THINK first before I tell someone something....
fourth.... after 25 yrs I think ive proboly been doing this longer then you....
if I wanted to be mean and dis you I would of told you to eat s*it and die
I have certs from merc, omc and volvo and you...???????
oh and no im not a hot shot just 42 yrs old been doing hp boats for a long time and no im not always right just not wrong often and dont like being put down when im not wrong if i am then go for it.. if your not 100% sure when you say something then say I think the iac only controls idle. dont mke it sound like you know 100% that im wrong when im not!!!!!!!!
I take alot of pride in my work and try not to be wrong
I dont survey boats
you do
do you want me to say more
Youve been wrong other times, I wouldnt be so high and mighty if I were you.
formula31 is offline
Old 01-10-2006 | 05:14 PM
  #44
stecz20's Avatar
i had nothing to do with this thread... do i still get in trouble???
stecz20 is offline
Old 01-10-2006 | 05:30 PM
  #45
375stinger's Avatar
hehe, you should have known better than post in the thread...now you're a culprit!
375stinger is offline
Old 01-10-2006 | 05:45 PM
  #46
GOODT's Avatar
no this time its just me
GOODT is offline
Old 01-10-2006 | 05:51 PM
  #47
CAP071's Avatar
[QUOTE=Edward R. Cozzi] YOU MIGHT AS WELL HAVE SUGGESTED HE TEST THE WINDSHIELD WIPER SWITCH!
QUOTE]
Funny You should say that......... It's a long story that I'll have to tell you sometime
CAP071 is offline
Old 01-10-2006 | 06:30 PM
  #48
yesrej's Avatar
stecz did it again
yesrej is offline
Old 01-11-2006 | 11:01 AM
  #49
[QUOTE=CAP071]
QUOTE]
I would love to hear that sometime, provided I can share my stories with you!
Edward R. Cozzi is offline
Old 01-11-2006 | 06:04 PM
  #50
stecz20's Avatar
you bad apple you........
stecz20 is offline
