Shorter drives? >
Shorter drives?
Shorter drives?
Old 01-24-2006 | 03:44 PM
  #31
Default Re: Shorter drives?
Kamma,
My Scarab does not have a notch. Straight Vee. I did not check the speeds at cruise. My guess is the cruise was up due the the Bravo 1 vs. the Mirage props.
BenPerfected is offline
Old 01-24-2006 | 06:20 PM
  #32
KAAMA's Avatar
Ben, thanks for the response....I also forgot to ask you how many cubic inches are your engines, supercharged or naturally aspirated, and what kind of power are they putting out if you happen to know? Thanks again.
KAAMA is offline
Old 01-25-2006 | 12:30 PM
  #33
Kaama,
At the end of the project, the engines were 505 ci @ 780 HP naturally aspirated. The top speed was 105 mph with Bravo I's 28p turning in (103 mph out) @ 6600 rpm. Add +2 mph to both with Herring 5-blades at the same 28p (Herrings - 200 rpm vs B-1's) I might have had slightly more MPH opportunity if I had Herring 27p to test with. At 9500 lbs. with 20-40 gal of fuel an two on board, this is a "hull efficiency" of 250...not bad for a 1987 straight vee.
Old 01-25-2006 | 12:56 PM
  #34
Originally Posted by BenPerfected
Kaama,
What you running as far as prop rotation ?
in or out ?
JaayTeee is offline
Old 01-25-2006 | 04:12 PM
  #35
KAAMA's Avatar
BenP,
The reason why I have asked is because your set-up is very close to mine, only I am not running as much HP or RPM's as you. I have a 1990 32' Active Thunder with a conventional "V" hull (non-stepped hull), and no notch in the tansom. The way my drives are set up are with Bravo One XR's on Stellings extention boxes with labbed 32" Bravo One four blades. The drives are stock length cases and they sit about 3.5 to 4 inches (prop shaft centerline) below the hull. I have a pair of IMCO -2" shorties pretty much ready to bolt on. I know that every hull is different, but it would be nice if I could tack on another 5mph as well----but as I have always said; "we shall see".
Anyway, it sounds like you have a very nice running rig. Thanks for your feedback.
KAAMA is offline
Old 01-29-2006 | 03:54 PM
  #36
Kaama,
My set up is also with Stellings extension boxes. Is the last 6-8' of your hull flat? Hook or rocker? This can be important for max top end. What length are your inside strakes in relation to your hulls CG? You may need do some fine tuning in length to get the attitude just right as you trade off some trim leverage with a high X. This is not a big deal... nothing money won't fix!
AAM
Sonic
3
08-09-2007 08:25 AM
Rebel_Heart
Prop Talk
3
05-14-2006 08:21 AM
Bryan Rose
8
02-06-2006 07:39 PM
Smitty
Baja
23
10-10-2005 08:17 AM
WildWarrior
Cigarette
13
07-13-2005 09:50 AM
