Bravo 1 upper compatible with Bravo 3 Lower? >
Old 03-07-2006 | 12:33 PM
Default Re: Bravo 1 upper compatible with Bravo 3 Lower?
Originally Posted by Big Block Billy
Many people around my area are going from bravo 1's to bravo two's on 24'-27' foot cabin cruisers with a single screw.
My sisters '97 27 searay had one. The boat did about 40mph with a 454.
A bravo two will make the boat handle better than a bravo one, and the boat will plane off better than a bravo one and will hold plane at a lower speed. and is way tougher than a bravo three.
Hit something with a bravo three, or even worse, get a piece of debris caught between the counter rotating props, and it's an expensive bomb that just exploded. Leaving you and those that you went out to enjoy a nice day of boating with now stranded, and then you saddled with a tremendous bill.
Bravo three's make boatyards tremendous profits.
A few years ago, My friend got stranded for almost a week upstate new york on the Hudson, as both of the 3's on his 29' Chapparal, let go after hitting something. He was forced to stay in a motel, and wait for his boat to be fixed.
He would not tell me how much it cost, he didn't want to talk about it.
That was the second pair of drives, Which Mercruiser actually provided new drives under warranty, which I installed. That wasn't the first time I had one of them apart earlier for a linkage replacement . Now on it's 3rd set when he decided to sell it. Not to bad for a 2 year old boat huh !
Even if Merc. has solved the corrosion issue, the Bravo Three is not that great, and costs too much to fix.
Here's a Bravo 2 lower I found on e-bay....BBB http://cgi.ebay.com/ebaymotors/LOWER...QQcmdZViewItem
What do you think about the Volvo DP?
Led Sled is offline
Old 03-09-2006 | 09:22 PM
Ok... You guys left me hanging here with that last bit of info about oil passages. How do I tell?
Led Sled is offline
Old 03-10-2006 | 10:24 AM
Big Block Billy's Avatar
here it is
BBB
Last edited by Big Block Billy; 03-10-2006 at 10:28 AM. Reason: PHOTO WOULD NOT GO THROUGH
Big Block Billy is offline
Old 03-11-2006 | 09:12 AM
Mbam's Avatar
Offshoreonly Advertiser
Led, you have a 2000 vintage drive, oil passages not an issue. The lower I have is 16/27 gears, will give you a 2.0 overall ratio with your upper. It's 2001 or newer as it has the later style vertical shaft, but not the dual anodes. Pics attached. No corrosion at all !!
Actually, now that I have the pictures I think I will put it on Ebay if you don't want it. I'll wait till Sunday.
Attached Thumbnails Bravo 1 upper compatible with Bravo 3 Lower?-b3lower1.jpg   Bravo 1 upper compatible with Bravo 3 Lower?-b3lower2.jpg   Bravo 1 upper compatible with Bravo 3 Lower?-b3lower3.jpg
Mbam is offline
Old 03-11-2006 | 09:31 AM
Hi, Glade to hear from you. Would it be to possible to send pictures to [email protected] ? And yes I'm seriously interested in it, I will not waste your time.
Thank you
Rob
Led Sled is offline
Old 03-11-2006 | 09:59 AM
Mbam's Avatar
Done
Mbam is offline
Old 03-11-2006 | 11:34 PM
Yes I want it.
Led Sled is offline
Gordo
27
04-21-2009 06:47 PM
Dave1972
6
03-30-2009 04:06 PM
handfulz28
Drives and Lower Units
12
05-14-2008 02:30 PM
thedonz
Wanted
0
04-15-2008 05:39 PM
Nova 26
23
06-03-2007 10:37 AM
