Sea Strainers Install ? >
Old 03-05-2006 | 05:15 PM
boatman22's Avatar
Default Sea Strainers Install ?
I'm installing sea strainers for my motors. The question I have from the experts (OSO Members), do they have to be installed below the water line?
The boat had none installed before.
boatman22 is offline
Old 03-05-2006 | 06:31 PM
Pwrbt33's Avatar
Talking Re: Sea Strainers Install ?
Its best to have them at or below the water line. This helps the supply to the sea pumps. In some boats I have had to mount them above just slightly. Once they were primed with water they didnt have a problem picking up water.
Also make sure you come into the top of the screen and pull water out under the screen.
John S.
Pwrbt33 is offline
Old 03-05-2006 | 06:34 PM
AKA NoMoBoatin
Default Re: Sea Strainers Install ?
Should you also install a water shut off valve on them too ?
docmanrich37 is offline
Old 03-05-2006 | 06:58 PM
Pwrbt33's Avatar
Alot of people dont on a Bravo because its supposed to be at the transom. I atleast install them into the sea strainer and connect my incoming hose to that.
John S.
Pwrbt33 is offline
Old 03-05-2006 | 08:58 PM
ratman's Avatar
run a ball valve before the strainer so you can turn off the valve when you're out and you need to clean debris out of the strainer.
ratman is offline
boatnt
06-15-2008 01:14 PM
DWES
Wanted
0
01-22-2008 04:44 PM
Mackattack
11-20-2007 12:07 PM
Donzi38ZXXX
13
04-01-2007 01:51 PM
customryder
6
05-31-2005 09:46 AM
