What size of socket for an Eagle H Beam Rod? >
Old 03-06-2006 | 09:35 AM
Default What size of socket for an Eagle H Beam Rod?
Guys I am at work and was going to purchase a new socket at lunch and I can not remember what size of cap screw is on the rod.
12 point 3/8?
JIM
1BIGJIM is offline
Old 03-06-2006 | 10:36 AM
TC's Avatar
TC
Default Re: What size of socket for an Eagle H Beam Rod?
I believe you are correct on the size if you are using ARP 2000 series bolts. I would purchase one of good quality. Mine got quite of a workout during assembly. If you plan on plastigauging to check your clearances you could be torquing, re-torquing and possibly changing to undersize/oversize bearings which means even more torquing.
TC is offline
Old 03-06-2006 | 10:41 AM
rws's Avatar
rws
1/2" 12 point.
rws is offline
Old 03-06-2006 | 10:50 AM
Wink Re: What size of socket for an Eagle H Beam Rod?
Don't forget to tighten the rod bolts up to the torque spec at leat 4-5 times to properly set the threads and pre-stretch on the bolts. This is the one problem most aftermarket rods can have after assembly, improper set up for final torque coupled with not properly checking bearing clearances and pin fit in the rods. If your going to spend dollars for good rods make sure you do the "right" job on checking and assembly! The socket size is the easiest but not the most important.
Ray @ Raylar
Raylar is offline
Old 03-06-2006 | 12:33 PM
So I will by a 1/2 and 3/8 12 point.
Actually the engine is assembled I was taking off some caps to make sure the bearings look fine. The mains are perfect. I found some shiny particals in my oil filter at the end of last season. I am hoping they were from the previoius spun bearing
No signs of metal in the pan or any where else so I am keeping my fingers crossed
1BIGJIM is offline
Old 03-06-2006 | 03:11 PM
formula31's Avatar
My eagle i beam rods are 7/16" 12 point. Hope you got the right sockets.
formula31 is offline
Old 03-06-2006 | 04:10 PM
GOODT's Avatar
be covered buy a complete set of 12 points !!!!!
GOODT is offline
Old 03-06-2006 | 04:47 PM
ratman's Avatar
measure rod bolt stretch the measuring gauges are about 60bucks but well worth it for the peace of mind, good luck
ratman is offline
Old 03-07-2006 | 06:50 AM
7/16 is the winner!
How can I measure rod bolt stretch when its a cap screw/bolt?
1BIGJIM is offline
Old 03-07-2006 | 07:00 AM
formula31's Avatar
Mine are threaded through and not blind. If your are open, you need the special indicator. It has extensions to go into the end of the threaded hole to get to the end of the bolt. The measurement is then from the head to the end of the bolt. Mics wont work. The end of the bolt and the head has a center cut on it to position the indicator shafts.
