Question about GGB Mufflers >
Old 03-08-2006 | 11:11 AM
Lofty's Avatar
Default Re: Question about GGB Mufflers
The biggest complaint on the GGB's is that they are too quiet at idle. Pulling the flappers out will fix this problem without making them too loud.
If you are running them dry you must remove the flappers. If you don't they will remove themselves in about a 1/4 mile! Dry systems are loud, period. If you add just a little water into the pipe just before the muffler you will get a huge reduction in dB's.
Lofty is offline
Old 03-08-2006 | 12:38 PM
rv
If you are looking at GGB's checkout:
http://www.offshoreonly.com/classifi...1&cat=5&page=2
rv is offline
Old 03-08-2006 | 05:49 PM
My boat with Keith Eickert manifolds and GGB transom mount mufflers registers 94 db at idle...
I had to install "down tubes" to meet the 86 db Wisconsin law
so now it blows bubbles in the water when at rest at 82db...But still sounds AWESOME once up on plane...
Doug
Boatally Insane is offline
Old 03-08-2006 | 06:12 PM
RLW
Doug,
I will have to perform a decibel test for comparision. I am also running KE's and transom mount GGB's with a single 540.
Are you running the Extreme Series?
94 db at idle seems high.
Russ
RLW is offline
Old 03-09-2006 | 06:01 AM
Originally Posted by RLW
Doug,
Russ
Yes, I am running the Extreme series transom mount mufflers.
I am also running a water circulating pump...It seems that guys running crossovers have a bit more water flow which makes the exhaust quieter yet....
Doug
Old 03-11-2006 | 11:09 PM
Boatally Insane,
I too will be trying to comply with the 86db in Wisconsin. Could you send me a picture of your "down tubes". Not sure how I'm going to quiet mine down..Please send a picture to [email protected]
Thanks.
Steve
Revd Up is offline
Old 03-12-2006 | 06:23 AM
Will the GGB clamp ons fit this application. The dry headers and tails are Stellings. The water dumps at the end of the tail via one tube. Will the water drain and blow through the muffler without problem with water reverting?
SkiDoc is offline
Old 03-12-2006 | 11:30 AM
Lofty's Avatar
We've put them on lots of Stellings. The water will blow through the muffler but I can't tell you that you won't have reversion. You shouldn't but it will depend entirely on your motor set up.
Lofty is offline
Old 03-12-2006 | 12:19 PM
zt260's Avatar
How does your water exit the tail pipes? I have stellings dry pipes, and there is a tube on the outside of the tail pipes that dumps the water. Exhaust and water never mix. I have seen stellings that dump inside the tailpipes just at the very end.
I run the ggb clamp on extremes. I drilled holes around the inside of my tail pipes to let water enter at the mufflers. You can also cut a hole in the bottle of the ggb's to let the water exit below if you want totally dry pipes.
They work very well.
zt260 is offline
Old 03-12-2006 | 07:33 PM
My Stellings dump inside through 1 tube at the very end.
SkiDoc is offline
