mounting oil coolers >
Old 03-14-2006 | 08:38 PM
johnnyboatman's Avatar
Default mounting oil coolers
bought teague coolers looks like they need to be mounted to the stringers, is it ok to drill 4 small holes in them and the silicone the holes before bolting. this looks like the strongest way to me these things are heavy.
johnnyboatman is offline
Old 03-14-2006 | 09:44 PM
GOODT's Avatar
Default Re: mounting oil coolers
YES
GOODT is offline
Old 03-14-2006 | 10:41 PM
vandeano's Avatar
Put some pics up when you have it mounted. The first oil cooler I bought from teague was the one with the power steering cooler built in and I had to return it because it was so long, and I had no place to mount it. I ended up getting the one with separate power steering cooler.
vandeano is offline
Old 03-15-2006 | 09:23 AM
formula31's Avatar
And use 4200. No silicone on a boat, only in boobs.
formula31 is offline
Old 03-15-2006 | 10:14 AM
Prater's Avatar
Better way is to drill oversize holes, then fill with epoxy. After it sets redrill the correct hole size and then through bolt. that way water will not get into the stringer.
Prater is offline
Old 03-15-2006 | 11:24 AM
formula31's Avatar
Yea, thats the best way.
dean51267
14
08-05-2006 12:07 AM
mcrsr
2
09-24-2005 07:13 PM
BRUCE SEROFF
6
03-27-2003 04:39 PM
TomR
17
07-23-2002 08:50 AM
MACDAD260
7
02-23-2002 08:57 AM
