#6 Prop Lock >
#6 Prop Lock
#6 Prop Lock
Old 03-21-2006 | 09:55 PM
Triple-Trouble's Avatar
Default #6 Prop Lock
Does anybody make a prop lock for a #6 drive?
Triple-Trouble is offline
Old 03-21-2006 | 10:20 PM
Default Re: #6 Prop Lock
the best prop lock is to remove them.......outta sight......outta mind......
pullmytrigger is offline
Old 03-21-2006 | 10:24 PM
44MTI's Avatar
McGuard makes one for the Blackhawk drive, it has the same size shaft and same threads. I have used it and it works great.
44MTI is offline
Old 03-22-2006 | 08:19 AM
rv
Do you have any problem with it loosing up. If you look close at the Bravo3 prop lock the base of the nut has a 45deg taper to it. The washer for the prop doesn't match the base of the nut. I am concerned there is not enough contact area between nut and washer.
rv is offline
Old 03-28-2006 | 04:30 PM
Airpacker's Avatar
The taper is to match the BH props. It can be easily machined off.
Airpacker is offline
Old 03-29-2006 | 07:41 AM
rv
Airpacker,
I thought about that but was concerned that there would not be enough of the threads/nut left. It looks like you would be reducing the area of threads by ~20%.
When I discussed this idea with McGuard they didn't thing it was a good idea. Any thoughts on this???
Rick
rv is offline
Old 03-29-2006 | 01:31 PM
Airpacker's Avatar
You don't have to machine the entire taper off, just enough to leave a good flat shoulder on the nut. Its self locking so it shouldn't come loose.
Buddy OO
06-08-2006 08:33 AM
Strip Poker 388
05-23-2006 11:28 PM
mark30h
11
03-22-2006 08:45 AM
Airpacker
2
05-09-2003 09:37 AM
