hydro locked ? >
hydro locked ?
hydro locked ?
Old 04-06-2006 | 06:43 AM
  #31
PatriYacht's Avatar
Default Re: hydro locked ?
Where do you boat? Up here in the spring it's still cold and the water temp is in the 40's. We get a lot of steam just from the difference in temp.
PatriYacht is offline
Old 04-06-2006 | 10:10 AM
  #32
I am in VA Beach . Yes so do we but one motor steams and the other doesnt. Im checking for some kind of water blockage or restriction in the motor in question now. If it was water temp problem they both would be steaming. Agree ?
boatman747 is offline
Old 04-06-2006 | 12:16 PM
  #33
PatriYacht's Avatar
Yes. What are your water temps at higher rpm's? If you are restricted in one engine, I would expect to see higher temps in that engine.
Old 04-07-2006 | 01:09 PM
  #34
Pulled all 8 sparkplugs . One plug was super clean ? # 5
drewwilliams is offline
Old 04-07-2006 | 03:13 PM
  #35
PatriYacht's Avatar
Your boat or Boatmans?
Old 04-07-2006 | 10:30 PM
  #36
offthefront's Avatar
thats where the leak is ..... the water/steam cleans the plug .....a leak in that cylinder
offthefront is offline
Old 04-07-2006 | 10:40 PM
  #37
GOODT's Avatar
if you want give me a call will tell / suggest what to do next...Sorry long day ( spring in the boat ind )
Joe
GOODT is offline
Old 04-08-2006 | 02:59 PM
  #38
Pulling the blower off tomorrow and removing head. Going to try to remove head with out removing the motor if possible. Aluminum heads , more than likely leaking around valve guide. .
Old 05-04-2006 | 05:30 PM
  #39
Ok , i pu;;ed the head had it checked , no leaks existed. Reassembled the motor with new manifolds and new risers . GIls. with 3 inch rise and aaaaaan eddie marine s pipe on the other end to get under Fountain swim platform . Motor runs fine but steams its butt off.Both motors steam pretty good now with this setup. Could the S pipes be the issue. To much restriction. I also have a little green foam in my valve cover s , only on the motor I tore down . Im thinking an Intake gasket leak. Still steams like crazy . Both motors steam hard.Maybe this set up is just going to steam until I get in the river.It might need alot of water ? Thats not available on a hose ?
RutRow
Grand Lake/LOTO/E-Dock
40
07-28-2008 01:35 AM
BLee
Cigarette
44
06-15-2006 10:49 AM
blakea502
09-14-2005 09:21 PM
CJC
01-08-2003 10:23 PM
Pure Energy
07-22-2002 11:56 AM
