Bad cams, components
Re: Bad cams, components
I agree with everything said and yes I made some bad judgements. On the engine builder as far as cost, he installed the cam and profile of my choice. He had no experience with ultradyne. Yes he purchased the cam kits but I told him wich ones to get.
I do feel like he is trying to resolve the situation as best he can.
Talked to ultradyne again today and all they are wanting to do is credit the 2 hyd cams and lifters toward the purchase of a set of roller lifters. Does not cover the cost of one set of roller lifters. 450.00 for the mark 4 reto fit rollers.
sure been a long road
Geronimo36
Been there, done that last year.
Didn't want to spend the extra dough to upgrade to a roller cam (penny wise, pound foolish). Wiped out a lobe and spent $2K to fix everything. Luckilly it didn't wipe out any bearings.
I'll never use a flat tappet cam again.
I wiped out a lobe on an Ultradyne flat tappet amost two years ago, and the camshaft had over 100 Hrs on it when it failed. Ultradyne went out of business and I think they were purchased by Lunati, aka Holley. So you are dealing with a company with much deeper pockets than the old Ultradyne of Mississippi.
I agree with the comments on Bob Maderra. This guys know his stuff and there is no body better to deal with.
A gentleman known as Hydrocruiser did a lot of research on this issue and here is a brief explanation-
There are oil additives that reduce metal to metal contact which are known as anti-scuffing agents. One of the best is ZDDP, a Zinc and Phosphorous compound, if i recall correctly.
ZDDP kills catalytic converters, so oil manufacturers have had to reduce ZDDP significantly in oils rated pimarily for gasoline engines (oil grades such as SF, SG).
Cams and lifters experience tremendous unit loads which can overcome the hydraulic cushion provided by oil, and the only thing that saves the parts from disaster is the anti scuffing agents and EP (extreme pressure) additives.
The reccomendations I have seen are to use oil additives that contain ZDDP- but some of these create their own set of problems such as oil frothing. Another solution is to run off-road only oils such as Valvoline Racing oil or specialty oil like Royal Purple or Amsoil. Mobil V-Twin is intended for Motorcycles and contains good stuff- the base stock is a true synthetic with a very good addditive package.
In the near future look for EPA/DEQ agents to be checking your purchases at Wal-Mart to make sure you don't home-brew some outlaw oil. Or maybe BATFMO will take that duty over.
how did you break in the camshafts???? i am not familiar w/ ultradyne but my own boat w/ 454's has comp cams in it, and i have had no problems, my camaro w/ a small block has a crower flat tappet, i spin that to 7000, motor has 40,000 miles on it, and gets thrashed pretty regularly, a couple of my customers boats(fountains, etc) are using comp cams marine cams w/ no problems, i usually run them on the shop floor(after prelubing) , running them at the advised 2000 rpm mark with varying rpm's for 20 minutes, then change the oil, i run castrol 20/50 in everything and have never had a cam fail in 10 years, i also use comps lube on the cam and base of the lifters, i have seen retro roller cams break the tiebar and chew up the cam, i have also seen roller wheel failure- so rollers have their share of problems-roller cams are expensive!!! it is nice to see that everyone here has deep pockets- it seems to be a requirement!!
Originally Posted by team Tickfaw
I do want to thank Bob Madera for his help so far and speaking with my engine builder. We are going to use his recommendations and purchase through him.
Geronimo36
Once the motor was broken in the oil was changed and the springs were reinstalled. Takes a lot of extra time to do this but in my mind it is worth it.
SORE MEMBER
1 Post
When you call Lunati, did you speak to Harold Brookshire? He was Ultradyne and is one of the most knowlegable cam people there is. He takes great pride in his designs.
I have run his custom grinds for years, both roller and flat tappet.
I understand the lobe issue, but what caused the lifter to break?
Originally Posted by MESABALANCING
No one is exempt from cam problems now days . Cam cores are being made in China and cam manufacturers are not using proper quality control standards. I build our poker run engines with hydraulic roller cams which are made by the leading cam manufacturer in the country and a couple of years ago I had problems with dist. gears going bad the manufacturer did nothing for me and I had to cover one hell of a warranty bill for a great customer. I go back to flat tappet cams have to be broke in on the dyno by the engine builder and the customer has to witness this for himself before it's put in the boat no engine builder should place an engine in a boat without testing and breaking the engine in first no excuses no dyno no payment there is no way for both parties to be sure averything is ok. That's not just broken engine but oil leaks water leaks temp issues ect. Best of luck Laz Mesa
Bob
Harold is not at Lunati anymore
