Where would I find a RELAY >
Old 06-03-2006 | 08:30 PM
Default Re: Where would I find a RELAY
If you're going to use an electromechanical relay and it is going to be installed in the engine compartment, it needs to be spark protected (like the solenoid on a marine starter motor). Using a relay that is used for something like a trim pump will be good. I decided to use a solid state relay for my electric fuel pump and picked it up from a NAPA store for $18. It's a NAPA "Echlin" AR168 30 amp relay. I haven't looked at the schematic for the criss-cross you need to do to reverse the polarity to the hatch motor for up and down, but the wiring to a solid state relay connects the positive 12 v from the control switch to terminal 85 & the ground to terminal 86. The 12 v positive from the battery connects to terminal 30, and terminal 87 goes to the hatch motor and then from the hatch motor to ground.
Escape Velocity is offline
Old 06-03-2006 | 09:01 PM
GOODT's Avatar
easy, use a trim or slave merc relay either will work......
GOODT is offline
Old 06-03-2006 | 10:13 PM
MOP
The older OMC' & Mercs used the Ford type for the assist, it will hold more AMP's the the new style and is fully spark protected. I have a few in my stash!
MOP is offline
10M
1
08-02-2008 07:27 PM
Warlock28SXT
5
06-28-2008 08:16 AM
Fast Forward
Powerquest
42
03-07-2008 07:01 PM
AGGRAVATION28
10
01-24-2008 11:09 PM
magnum
6
04-09-2004 04:18 PM
