Drive ratios >
Drive ratios
Drive ratios
Old 06-17-2006 | 08:12 PM
nordic95's Avatar
Default Drive ratios
What gear drive ratios are available for the XR.And what effect would they have on prop pitch???
Thanks Nordic95
nordic95 is offline
Old 06-17-2006 | 10:06 PM
Smitty's Avatar
Default Re: Drive ratios
1.36 and 1.50 you most likely would best go with the 1.50
I just changed from 1.36 to 1.50 and the boat is more responsive.
There is about 2 inches of prop pitch between the two. I was running 28" props on the 1.36 and now I am running 30" props with the 1.50
Smitty is offline
Old 06-18-2006 | 09:32 AM
Smitty, when you changed to the 1.50 did you lose top end??
ghittner is offline
Old 06-18-2006 | 11:21 PM
rbtnt's Avatar
Here's some addtional gear ratios.
http://www.mtboats.com/outdrivegearratios.html
www.mtboats.com - Pages of boat related links
rbtnt is offline
Old 06-20-2006 | 10:18 PM
Smitty's Avatar
Actually I have gained 2 mph and feel that there is 2 mph left by spinning my props in, which I am going to try this weekend.
By changing ratios I am getting the motor to spin more revs closer to max rpm, which is also based on boost levels.
Smitty is offline
gsxrscooter
Drives and Lower Units
4
06-11-2007 08:56 PM
awsomethunder
5
01-19-2007 07:00 PM
Grog
3
05-17-2006 04:49 PM
PROMAN
Sonic
5
10-21-2004 10:11 PM
WETTE VETTE
2
02-23-2004 04:16 PM
