Old Bravo lower W/ new Bravo upper? >
Old 07-11-2006, 01:36 AM
articfriends's Avatar
Default Re: Old Bravo lower W/ new Bravo upper?
Here you go,VIP has 1/4 drill bits 12" and 18" looooong,Smittyhttp://www.valleyindprod.com/shopping/index.php?cPath=161_180
articfriends is offline
Old 07-11-2006, 01:38 AM
http://www.valleyindprod.com/shoppin...?cPath=161_180
browse as a visitor,go to special drills, they have a 1-800# to order but find your part# first because you'll probably be talking to a operator or order taker,Smitty
Old 07-11-2006, 05:11 AM
Charter Member #601
Mr Gadgets's Avatar
Thanks Smitty...
Mr Gadgets is offline
Old 07-11-2006, 08:55 AM
Charter Member #94
Gordo's Avatar
Thanks for the link Smitty
Abby-someone
Gordo is offline
Old 03-30-2009, 01:12 PM
Default new bravo 1 lower replacing 1990 bravo lower
So if i understand everybody correctly all i have to do to use a 2000 bravo one lower on a 1990 bravo one upper is plug the oil hole on the new lower? What do i use to plug the hole is my next question?
rarenivas is offline
Old 03-30-2009, 08:47 PM
Charter Member #601
Mr Gadgets's Avatar
If there is no hole in the upper housing then just tap the hole i the lower and install a small stainless set screw with a hex socket (?) that you would screw in with and allen wrench.. Use some red locktite on it and make sure it is flush with the top of the lower case. The smaller the set screw the better, in case you want to ever use it on a newer upper..
Hope this helps.
Dick
Old 03-31-2009, 05:32 PM
Default thanks
thanks, I will give it a try.
Old 04-21-2009, 06:47 PM
blue thunder's Avatar
I am doing the same this week to two drives; old uppers w/ newer lowers. It appears the thread size that would fit without drilling is 5/16-18. That's what I am going to put in anyway. Now I have to find of SS set screws, that should be fun
blue thunder is offline
Dave1972
6
03-30-2009 04:06 PM
handfulz28
Drives and Lower Units
12
05-14-2008 02:30 PM
thedonz
Wanted
0
04-15-2008 05:39 PM
docmanrich37
5
09-16-2006 07:42 PM
Led Sled
26
03-11-2006 11:34 PM
Quick Reply: Old Bravo lower W/ new Bravo upper?
