water found in oil, any hope for engine? >
Old 07-20-2006 | 08:45 PM
Hydrocruiser's Avatar
Arrow Re: water found in oil, any hope for engine?
...so you found oil in your water?
Hydrocruiser is offline
Old 07-21-2006 | 12:32 PM
mjb
Default Re: water found in oil, any hope for engine?
I have used the sludge disoving addative several times. I can't remember the name of it but I do remember that it was easily available at most auto parts stores.
mjb is offline
Old 07-21-2006 | 06:38 PM
cuda's Avatar
Originally Posted by jmherbert
I've heard lots of people do that with no problems, but I am just too wussy to try it myself.
Trust me, diesel has a lot better lubricating qualities than gas does. That's one of the reasons there was fuel injection in diesels before gas.
cuda is offline
Old 07-21-2006 | 08:37 PM
Hopefully, I'll never have to go thru that excercise again
jmherbert is offline
Old 07-22-2006 | 02:04 PM
DRIVEN1's Avatar
Originally Posted by mtocrs1
Had same problem this spring, Changed oil 5 times and have been running WFO ever since with no problems.
I had the leaky headers. Fixed the headers and put in fresh oil. Ran for about 4 hours and changed again. The motor has been run for another couple hours and appears to be milky again. Not as milky as when headers were leaking or after the first oil change with new headers.
My question would be with 2 oil changes should I still be getting the milky appearance? I hope to god the headers are not leaking again. I am going to change the oil again this weekend and see what happens. Thanks Mike
DRIVEN1 is offline
Old 07-22-2006 | 02:34 PM
BY U BOY's Avatar
IT CAN TAKE SEVERAL OIL CHANGES TO GET RID OF THE MILK.
BY U BOY is offline
Old 07-22-2006 | 05:56 PM
DRIVEN1's Avatar
Thanks.
DRIVEN1 is offline
Old 07-22-2006 | 06:39 PM
cuda's Avatar
Yep, that's why I say run the oil/diesel combo. Usually cuts it all out in one shot.
cuda is offline
Old 07-22-2006 | 07:01 PM
GOODT's Avatar
Most of the water residue will steam off as you run the boat but make sure you change the oil no less then 3 times
GOODT is offline
Old 07-26-2006 | 09:11 PM
Will it steam off thru the exhaust ? I am experiencing the same thing when my innercooler blew. It is steaming like crazy, is it a result of the water in the oil? Steams bad at start up but gets very mild after a few minutes.? How can I tell if a intake manifold gasket blew or a head gasket blew/ ? I wa wide open and the rpms wentto 1500. Im thinking when the cooler blew it deluted the gas. It runs fine now but steams like crazy and the inner cooler is not even plumbed yet ..
melinda williams is offline
Vinny P
35
08-11-2008 08:50 PM
jeff32
06-28-2006 08:48 AM
duksrule
06-08-2006 09:44 AM
KBUSH1
4
06-16-2004 06:45 AM
Monty
14
01-29-2004 10:59 PM
