HP500s Carb build-up >
Old 07-26-2006 | 08:56 AM
t500hps's Avatar
21 and 42 footers
Default Re: HP500s Carb build-up
Originally Posted by BajaRunner
Russ
how fast does it run with the prochargers?
Not sure....I haven't even been on the boat yet. I have been told 98 when it was first installed (boat was new), I've heard near 95 (sometime after it was delivered), and I was told 85 on the water last week with the drives tucked IN!!! (can't verify any of this). It is a M3 intercooled system running un-known boost. Probably 5-8 PSI. Like I said I will be selling the entire Prochrager systems this fall and going back N/A EFI.
Stock 382 with 500's should run 74, a new 382 w/ 600's runs 84, the 700's supposedly hits 93.
Russ C.
t500hps is offline
Old 07-26-2006 | 08:59 AM
i am also going to pull my 500s this winter and shoot for 600 hp so i am also interested in any input. i know excursion on here did his 2 winters ago to around 600 hp i beleive. would be nice to get all the info as what to use from someone who has done it with good results.
rssteiny is offline
BajaRunner's Avatar
Russ C.
Let me know when you sell em. I may be looking for some for my 500's.
BajaRunner is offline
Old 07-26-2006 | 10:26 AM
SB
Keep carb (Holley 800)
Keep intake (Dart)
Cast Iron heads ported by Jim Valeko or New Aluminum AFR's with valvetrain spec'd by RmBuilder
Cam by RmBuilder
Shortblock can be stock - just make sure it is fresh.
Exhaust is important and expensive. Do this correctly.
Prop to where engine makes peak hp. Do not lug it by propping in between torque peak and hp peak.
SB is offline
Old 07-31-2006 | 07:50 AM
Dean Ferry's Avatar
Veteran: Air Force
SB,
Thanks for the recommendations.
Dean
Everything is for sale @ a certain $$
Dean Ferry is offline
Old 07-31-2006 | 10:03 AM
augie58's Avatar
Dean and everyone
let's keep this thread alive thru the winter as there are alot of us with 500's that are due for freshining and upgrading.
augie58 is offline
Old 07-31-2006 | 12:44 PM
Here is a link to the build I did on a 502 Mag last year....
http://www.offshoreonly.com/forums/s...d.php?t=101736
I have 74 hours on it so far and it's STILL runnin' strong
Doug
Boatally Insane is offline
Old 10-13-2006 | 02:24 PM
Bringing this back up to see if anyone has started their build I am meeting with my engine guy this weekend. I am looking to make between 600-650 from my 502. I would like to hit aprox upper 70's in a 29 single scarab running a 28 pitch prop.
custom29scarab is offline
Old 10-13-2006 | 09:38 PM
axapowell's Avatar
Where To
Good luck with the build...PM me if I can help!
Dave
axapowell is offline
Old 10-13-2006 | 10:22 PM
cuda's Avatar
No, but I did buy the base stuff. I'll probably just change springs, headgaskets, clean it up, and call it good.
Attached Thumbnails HP500s Carb build-up-9-26-003.jpg   HP500s Carb build-up-9-27-001.jpg   HP500s Carb build-up-10-13-06-001.jpg
cuda is offline
