How do you pull engine with TRS drive / BW tranny ? >
Old 09-09-2006 | 03:46 PM
Donman's Avatar
Default How do you pull engine with TRS drive / BW tranny ?
I need to pull my port engine. I`ve got TRS drives / Borg-Warner transmissions.
I`ve pulled engines with Bravo drives, so I already know the basics. But how do you pull engine if it has a tranny behind it ?
Do I need to pull eng / trans as a unit or what ?
TIA
Donman is offline
Old 09-09-2006 | 03:49 PM
nocigarette's Avatar
Default Re: How do you pull engine with TRS drive / BW tranny ?
I Have A #3 And Velvet Drive I Just Unbolt It Straight From The Engine, And Leave The Trans Bell Housing Right In The Boat
Attached Thumbnails How do you pull engine with TRS drive / BW tranny ?-magnum-100.jpg
nocigarette is offline
Old 09-09-2006 | 04:05 PM
We just pulled a HP800/SSM III yesterday. We left the tranny on the motor. Just make sure you have enough room in front of the engine. You need to pull the engine forward and up.
Drive removed of course. Took about 2h. from start t finish.
Hydrolift is offline
Old 09-09-2006 | 04:09 PM
Donman's Avatar
I don`t have much room in front of engine. Looks easier to leave bellhousing attached to trans.
So --- How do you line up engine upon reassembly ?
With this method, do you have to pull drive ?
Donman is offline
Old 09-09-2006 | 04:12 PM
I Dont Pull My Drive, Its Pretty Easy Just A Little Wiggling And It Should Pop Back In.......
Old 09-09-2006 | 04:15 PM
You will need to re align it after putting it together, so you will need to pull the drive.
I am no pro at this so...
Old 09-09-2006 | 07:43 PM
If you separate engine block from bell-housing and leave the bell-housing/tranny in boat, there should be no reason to re-align on re-assembly. (and of course, this way you don't mess with the outdrive at all) --- Jer
jpclear is offline
Old 09-09-2006 | 07:52 PM
Why don`t you need to re-align? the tranny is mounted on to "ears" on the inner transom and can be moved up or down when the engine is removed. If the engine is tilting more up or down when reinstaling then the alignment will be off, wouldn`t it?
Just curious, newer put one back inn. First time this time
Old 09-10-2006 | 09:30 AM
Donman's Avatar
This makes sense to me. It almost sounds too easy.
I`m off to the shop --- engine should be sitting on the floor in a little while.
Then pull the camshaft...
Donman is offline
Old 09-10-2006 | 09:46 AM
AS LONG AS THE ENGINE IS GETTING BOLTED BACK IN THE SAME PLACE IE THE BRACKET IT IS IMPOSSIBLE FOR IT TO BE MIS ALIGHNED..............IT IS GOING BACK IN THE SAME EXACT POSITION//////////
302Sport
Wanted
2
05-11-2008 08:32 PM
djtalon
1
05-07-2006 06:37 PM
Prater
4
01-25-2006 05:22 AM
Poorsche
13
04-15-2004 09:26 PM
bford1
03-12-2004 08:37 AM
