Put drive on and now starter grinds >
Old 09-25-2006 | 07:31 PM
Default Put drive on and now starter grinds
Trs drive was real hard to get on the last 1/2 inch. Now that the drive is installed every other time i go to start the engine the starter will grind. If i click it a couple of times the bendix will engage totally and crank the engine. What would cause this? Drive shaft pushing against tranni and that pushing flywheel??
djtalon is offline
Old 09-25-2006 | 07:47 PM
jeff32's Avatar
Default Re: Put drive on and now starter grinds
Hard to tell. The drive shaft goes in the trannie but this part as far as I know does not spin unless you engage the transmission. So I don't see why it would give a hard time to the starter to turn the engine. So, I would guess a starter problem.
Anyboby else? I'm just a beginner with TRS on my boat...
jeff32 is offline
Old 09-26-2006 | 06:03 AM
MOP
No way are the two related, pull the starter to find the cause.
MOP is offline
Old 09-26-2006 | 08:16 AM
GoCiggie31's Avatar
From: Where the water meets the oaks 'n Pines in the Sierra Nevada's of NorCal
double check the mounting starter bolt torque.
GoCiggie31 is offline
Old 09-26-2006 | 11:28 AM
Reckless32's Avatar
Rough Seas Lie Ahead
Starter mounting bolt shims?
Reckless32 is offline
Old 09-26-2006 | 12:22 PM
Wally's Avatar
Were doomed!
you may only have shims if the starter is mounted to the block like it would be on a car/truck application. Most TRS setups i've seen or dealt with had the starter mounted on the top/rear of the bell-housing......installing the outdrive shouldn't have any affect on the starter or flywheel....there's something else causing you problems...maybe the starter bolts are loose...or a chipped tooth on the flywheel....or the starter itself is going bad...
-Wally
Wally is offline
fastboy
08-30-2007 09:01 PM
Hot Boat
13
02-07-2007 06:53 PM
p4-33
17
03-20-2006 10:17 AM
nobudget
2
04-21-2002 09:53 PM
blue thunder
16
01-17-2002 09:45 AM
