Changing Drive Oil in the Fall >
Old 10-08-2006 | 10:03 PM
Rebel_Heart's Avatar
Default Changing Drive Oil in the Fall
I have always had my drive oil changed prior to laying up for the season. I am going to play around with shorties in the spring, is there any down side to leaving the oil in over the winter months. I will have about 12 hours on the new engines and the drive oil was changed at that time. Using Amsoil 70/85-90w synthetic oil. Thanks.
Rebel_Heart is offline
Old 10-08-2006 | 10:32 PM
axapowell's Avatar
Where To
Default Re: Changing Drive Oil in the Fall
Only downfall could be if there is any water in the oil. If it freezes...it will be an issue. With only 12 hours, as long as the drives don't have any leaks, you should be alright. For the insurance, I'd spend the bucks to drain and fill.
Not sure about leaving them empty though?!?
Dave
axapowell is offline
Old 10-08-2006 | 10:54 PM
I wouldn't give it a second thought with only 12 hours on the lube.
Griff is offline
Old 10-10-2006 | 11:35 AM
Crack the drain bolt. If no water comes out and the lube looks good, leave it. If not, change. Ken
minxguy is offline
Old 10-10-2006 | 08:06 PM
I will take a look at it. Thanks for the replies.
aquatictherapy
Drives and Lower Units
4
06-07-2007 11:26 AM
pondrocket
Fountain
5
08-09-2004 08:00 PM
bn
4
05-22-2002 08:33 PM
magnuman
1
04-21-2002 02:43 AM
BAJA WILL
3
04-16-2002 10:03 PM
