700 sci
Old 11-04-2006 | 11:18 AM
gsmith9898's Avatar
Default 700 sci
Will the new 700sci bolt up to a regular bravo xr or does it have to mount up to that new nxi outdrive only?
gsmith9898 is offline
Old 11-04-2006 | 04:30 PM
Strip Poker 388's Avatar
Rob
Default Re: 700 sci
as long as there no sensors or other stuff from the belhousing back .I would think if you used every thing from a bravo bellhousing back it would bolt up.I am sure its a aftermarket block like dart
Strip Poker 388 is offline
Old 11-04-2006 | 05:42 PM
gsmith9898's Avatar
Default Re: 700 sci
it says that it is designed off the same same motor as the 525. The only reason I was wondering is that they will only sell that new drive with that motor. I was wondering if I could pull my 525 and put in the new 700sci or the 1050sci.
Old 11-04-2006 | 05:56 PM
Cool Re: 700 sci
I didn't think a bravo XR would take much over the 700SCI horses?
Donzi38ZXXX is offline
Old 11-04-2006 | 10:45 PM
gsmith9898's Avatar
Default Re: 700 sci
I was just wondering if they would bolt up or did it have to match up to the new drive system.
Old 11-04-2006 | 11:16 PM
bblythe's Avatar
Default Re: 700 sci
it runs a trans like a #6 DRIVE(between motor and drivethere is some speical setup on water to warrenty motors
bblythe is offline
Old 11-05-2006 | 06:13 AM
Payton's Avatar
Charter Member #927
Default Re: 700 sci
In order to get one you would have to find a Merc Dealer to split up the combo for you. But that may get them in trouble with Merc.
Payton is offline
Old 11-05-2006 | 10:29 AM
Default Re: 700 sci
Not sure why you wouldn't want to install the drive too? You can leave the engine location right where you have it, drill and cut the transom, and install the drive. I think the propshaft ends up a little over 1" higher than a shorty sportmaster.
I guess there are always other things to think about. Going even higher (mounts, and possibly some consequences on the cutout). Steering, you will need a helm at a minimum. I am sure there are always some other minor problems too.
Falcon is offline
Beak Boater
25
08-25-2011 07:07 AM
pokerrunboats
17
07-14-2008 06:23 PM
Chuck
07-02-2008 09:26 PM
RLopez9014
12-19-2006 09:38 PM
Superbabi
6
02-24-2006 01:35 PM
