Gas overflowing >
Gas overflowing
Gas overflowing
Old 11-29-2006 | 04:04 PM
dykstra's Avatar
Default Gas overflowing
My uncle has a 22' 2006 Stingray and after starting to fill the tank with fuel it erupts all over the place. The tank is NOT full. Any thought as to what this problem is?
dykstra is offline
Old 11-29-2006 | 04:22 PM
AKA NoMoBoatin
Default Re: Gas overflowing
Mine did the samthing this summer and was told fuel got into the vent tube and blocked it off from some ruff riding.After a ruff run one weekend it went back to normal.
docmanrich37 is offline
Old 11-29-2006 | 05:55 PM
Dave M's Avatar
Veteran: Navy
Every gas nozzle and every boat seem to be different. Start out pumping REAL slow. Try inserting the nozzle at different angles too. Sometime I can stick the nozzle in and crank it up full blast, other times it keeps clicking off.
Dave M is offline
Old 11-29-2006 | 06:15 PM
Downtown42's Avatar
yep.
Downtown42 is offline
Old 11-30-2006 | 12:22 AM
dykstra's Avatar
Thanks for the feedback! I'll let him know. Better yet, I will tell his cheap azz to subscribe to OSO!
dykstra is offline
Old 11-30-2006 | 06:03 AM
Payton's Avatar
Charter Member #927
I had the fuel vent get plugged up on my Father-in-laws Rinker one time. I don't know which insect it is, but something built a mud nest right over the screen. I scraped it out with a little srew driver and no more burping fuel fill.
Payton is offline
Old 11-30-2006 | 09:29 AM
UNSANE's Avatar
I used to have a Stingray 220SX. This is a problem with them. The venting is inadequate. Run the pump at a lower speed and when he thinks he's getting close to full, put it on the lowest speed possible.
UNSANE is offline
Old 11-30-2006 | 12:07 PM
check the vent line,they put a loop in them to keep water out of the tank.Mine had a kink,took me 2 years to find it !
roarkace is offline
Old 12-04-2006 | 06:31 PM
add a second vent line most tanks have 2 vent locations but only use 1 some mfg. will fix under warr.
phil0460 is offline
Old 12-05-2006 | 09:48 AM
Blue by You's Avatar
FIERCE ALLEGIANCE
Guns never seem to ride ruff like the AT's so I can't really help you out here. But Rich fills his tank pretty often so he should know!
Blue by You is offline
cprperformance
27
08-04-2021 09:03 PM
JBoat
07-01-2008 05:42 PM
baronbob
25
05-01-2004 05:32 PM
kbush2
7
06-19-2003 04:44 PM
fountain10
7
12-05-2002 08:08 PM
