Sea pump pressure >
Sea pump pressure
Sea pump pressure
Old 12-25-2006 | 07:03 AM
Default Sea pump pressure
I searched the forums but I could not find this answer. I noticed stbrd engine temp rising (by the way I have twin 496 ho 's with smartcraft hooked up thru northstar) I did bump a sandbar the day before so I assume I picked up sand, but after reading thru the forum most people say they lose sea water pump pressure but mine goes 20 psi higher and temp runs about 5-10 degrees higher. I have never had alarms or shutdown, I was going to pull the hose off of heat exchanger and backflush back to pump, any other advise? Thanks
pennys spent is offline
Old 12-25-2006 | 10:49 AM
sakoutis3's Avatar
Default Re: Sea pump pressure
Sounds like you had the impeller come apart and its now creating a restriction.
sakoutis3 is offline
Old 12-25-2006 | 10:53 AM
US1 Fountain's Avatar
Ginger or Mary Ann?
Sounds more like a blockage on the exit side of wherever the pressure gauge is mounted. Not letting the water escape, thus higher pressure and temps. Not necessarily a wiped out impellor. Just a thought.
Those that have lost pressure have usually wiped out an impellor or plugged up a cooler/strainer on the inlet side from where the press gauge is mounted.
US1 Fountain is offline
Old 12-26-2006 | 12:09 PM
ok first I'll check the impellor but where is pressure reading takin from. I assume the impellor would reduce water pressure.
BillR
11
07-29-2022 06:31 AM
alecsammy
0
09-21-2008 09:47 AM
HP500Hammer
15
01-30-2008 06:03 PM
Rage
2
05-15-2006 08:31 AM
28Eliminator
11
06-22-2004 10:43 PM
