compairing out drives >
Old 12-29-2006 | 07:29 PM
Default Re: compairing out drives
Originally Posted by Panther
All things being considered you can't go wrong with a #5 or #6. In some cases the #5 is actually faster than the #6.
For me the Konrad would be the second choice.
If price is a problem, sell your XR and get a BMax HT. It's the cheaper route of the three and should cost around $10K minus whatever you sell your XR for.
Just my humble opinion.
I like the idea. What is the hp rating on a #5?
Also is it true that the #4,#5,#6 are considered surface drives?
tomcei is offline
Old 12-30-2006 | 09:29 AM
Panther's Avatar
Frank's Marine Service
I'm not entirely sure what the rating is but I've seen people run 1000 - 1200 hp with them.
#4's are discontinued, the 3,4,5 were a measurement of the depth to the drive, 3 being the deepest and 5 being the highest. Back in the day some of the older triple engine raceboats had a #3 in the center engine and #5's on the outside engines. I think Kid Apache was set up this way???
They are all surface drives, hence the cleaver style surface props. Another thing I would consider is the cost of props for a #5 vs. a Konrad/BMax, it's a huge difference and they're a lot less available.
Panther is offline
Old 12-30-2006 | 10:22 AM
NJSONIC's Avatar
I would say a Konrad would be like a #3 but with a slightly higher horsepower rating. I was told 750 on a #3 to have a reliable package. I'm running 800's with Konrads. No problems to date. Just working on props.
NJSONIC is offline
Old 12-30-2006 | 11:39 AM
Elite Marine's Avatar
There is a very nice pair of slightly used Imco 4X4's donw in FL by Larry Goldman. Decent price too.
Elite Marine is offline
Old 12-30-2006 | 12:11 PM
I saw those,thanks.
I'm ready for more pics kirk
tomcei is offline
Old 12-30-2006 | 12:14 PM
monstaaa's Avatar
the length of the boat as awell as a weight is very important to your decission. sixes weigh more and affect the c.g more as well. 5's are readily available as mentioned above, and wil as astated survive severe punishment.
b max is not a choice from a strength perspective, being if you dont match their drive with their gimbal, you now created a second week lynk. as is any bravo style/ design drive system ,again no need to elaborate.
monstaaa is offline
Old 12-30-2006 | 12:38 PM
Strip Poker 388's Avatar
Rob
Bo do you see the Merc HP [XR] gimble as a week link in a high Horsepower stand point??
The Bmax ,Max, Imco[bravo style] bolt up just like a stock Bravo. I wouldnt think the differant kind[namebrand] of drive wouldnt put more stress on a gimble.
Rob
Strip Poker 388 is offline
Old 12-30-2006 | 01:03 PM
monstaaa's Avatar
a stronger bravo style drive on bravo gimbal or an i.t.s gimbal is not good from a mate standpoint, nor for a person with a heavy throttle hand. especially adding say a b-max. your increasing the load of the mechanical leverage agianst the original design,by increasing the weight of the drive itself. thus increasing the failure rate in critical areas ,like the pivot pins, and the helmut. i have seen this many times , and more so in conjunction with the use of the b-max. all your doing is moving the weak link from one area to another.
as far as the merc gimbal beeing the week link, it would depend on the boat length and weight. again mechaincal levrage comes into play as well as the c.g.
lastly and most importantly when a product is used in a fashion above and beyond its original design failure isnt possible it;s eminant.
although gary and i have routinely pushed his gladiator over the 100 mark with out any failure in the engine, gimbal, or drive, i would say this attests to frquent checks of all moving parts, good design,and proper opperation in that relm.
remember hevy hands yeild heavy hits especially when punching a WET PAPER BAG.
monstaaa is offline
Old 12-30-2006 | 01:11 PM
monstaaa's Avatar
p.s strip i love the rooster skit l.m.a.o
monstaaa is offline
Old 12-30-2006 | 03:05 PM
The boat in question is a 28 Pantera single engine.
Does anyone think this is to stern heavy with a #6 ? I wouldn't think it would be as bad as twins w/ bravo's on the c.g.
I assume the #5 is a lighter assmy.
I certinly don't want to change the handling too much. I does seem to be balanced very well.
tomcei is offline
