Bravo Alignment Tool >
Old 04-30-2007 | 08:02 AM
25 hors la loi's Avatar
Originally Posted by Gizmo
Hey 25, is that a drive stand in the photo of the finished alignment tool? If so, can you post a picture of it assembled?
Yes ...for sure ...soon i have finish paint it ...i will post picture ...in the end of the week ...
Regard`s
25 hors la loi is offline
Old 04-30-2007 | 08:26 AM
Originally Posted by 25 hors la loi
Can you check guy ...if my dimension is Ok ??
Thank`s to take time
Ho yes it`s for the Bravo side
i have to recheck my job .....cause i try my tool in a boat of my brother in-law ...(and we have no difficulty to remove is drive this is why i think the alignment is Ok ) ...and when it`s time to insert the tool ...i am not able to came in the engine coupler ...go figure ....wich measure i have to redone
Old 05-01-2007 | 07:19 AM
Originally Posted by Wally
yup...looks just like my dwg.
I don’t know why ....but the beginning of the tool we have 1.118 with your drawing ....and my father go to a boat dealer yesterday ....and he measuring a tool and the measure is 1.010 ...look like we are .108 to big .....i continue my research .....no one have the same concern ???
Old 05-01-2007 | 10:27 AM
Wally's Avatar
Were doomed!
Well if you look at my first drawing that shows the two ended tool for Alpha or bravo it shows on the Alpha side that its 1.011 in size on the end....and if you also look at the second pic that shows the update/modifcations at the bottom it reads "The modified 91-57797A3 tool or the new tool 91-805475A1 will align all current Alpha or Bravo models as well as all older engines that used the older 91-57797A3 tool"
So that would lead me to believe that you would need to make you tool to the original alpha side specs WITH the midifcations from the second pic......
-Wally
Wally is online now
Old 05-01-2007 | 10:28 AM
Wally's Avatar
Were doomed!
maybe the older Bravo's had slightly different sized couplers??? i dunno
-Wally
Wally is online now
Old 05-01-2007 | 10:52 AM
Wally's Avatar
Were doomed!
so maybe the tool needs to look like this:
-Wally
Wally is online now
Old 05-07-2007 | 02:52 PM
98itrwhite's Avatar
Originally Posted by whoya
I sell them.
THIS IS A BRAND NEW "CNC LATHE CREATED " MERCRUISER ENGINE ALIGNMENT TOOL.
GREAT ITEM TO HAVE IN THE GARAGE.
THIS TOOL REPLACES MERCRUISER OEM #91-57797A3, WHEN THIS TOOL WAS AVALIABLE THRU MERCURY IT WAS ALMOST $100.00
THIS IS USED TO CHECK ENGINE COUPLER ALIGNMENT WITH THE GIMBAL BEARING.
PROPER ALIGNMENT PREVENTS WEAR ON THE BEARING,DRIVE AND COUPLER.
FOR USE WITH: MERCRUISER DRIVES 1,1A,1B,1C.ALL#1 DRIVES - ALL BRAVOS - GENERATION 2- PRE ALPHA "R"-ALPHA ONE - ALL OMC COBRA STERNDRIVES - VOLVO SX.
EVERYTIME YOU HAVE THE DRIVE OFF YOU SHOULD CHECK ALIGNMENT OR IF YOU HAVE PULLED OR ADJUSTED THE ENGINE.
THIS TOOL CAN SAVE YOU COSTLY DRIVE REPAIR AND COUPLER REPLACEMENT.
$45.00 plus shipping give me a zip and i will give you a DHL ground price.
Thru Paypal secure for both of us
just got mine today, cant beat it for the price and service
98itrwhite is offline
Old 05-07-2007 | 04:00 PM
But be able to do it yourself .....is.......... pricelessssss
Regards
Old 05-21-2007 | 01:01 PM
I bought one of the A1 tools and there's no way its going to work with a alpha, I called the shop I bought it from and they say the ones they use in there shop measure out to 1.118. Even the directions that came with tool say it will work with alpha drives. Whats the deal with tool.
deerob5000 is offline
Old 06-08-2007 | 11:19 PM
jharran's Avatar
Will the Bravo alignment tool work on my XR drive? what is total price to ship to 86406. Thanks Jeff
jharran is offline
