bbc heads for blowers >
Old 01-11-2007 | 06:39 PM
Fenderjack's Avatar
Pirate of the Chesapeake
Default bbc heads for blowers
Im building a set of blower motors.What do you guys think is the best out of the box cast iron heads, cant run alum,I'm on the cheasapeake bay salt water,and very few places to have 93 octane fuel. would 500hp merc heads work.I can get a pair local off my buddies boat!!!! Thanks JOHN
Fenderjack is offline
Old 01-11-2007 | 07:15 PM
Beak Boater's Avatar
Charter Member # 545
Default Re: bbc heads for blowers
Depends on the cam and amount of boost. You can run aluminum heads, AFR, for one, coats the water jacket to resist salt water corrosion. I think their are other Alum. head makers that also coat them. I ran 2 sets of AFR's on 540's with whipples, alittle farther down the bay on the Potomac, Patuxent, and in the bay. The motors had over 200 hrs on them, and no problems. These were the uncoated heads. They also spent one winter in the Fla Keys, in salt water. The extra protection of Alum. heads on a blower motor is worth it. Good luck. Im sure some of the engine builders will chime in with recomendations. But the fact that you run in salt water shouldnt deter you from using Alum. heads if you want too
Beak Boater is offline
Old 01-12-2007 | 12:28 AM
articfriends's Avatar
I can tell you what NOT to buy,the merlin vrs are set up nice with inconel valves and ok springs but they offer very little performance gain over 088 rectangle ports,Smitty
articfriends is offline
Old 01-12-2007 | 06:42 AM
DiamondPerformance's Avatar
Offshoreonly Advertiser
You will be much better off with aluminum heads, don't worry the AFR Heads will be alright with the coating.
www.diamondperformanceparts.com
[email protected]
http://www.facebook.com/pages/Diamon...07878772615803
302-521-0123
The Best Parts & Service At The Best Price
DiamondPerformance is offline
Old 01-12-2007 | 07:27 AM
boss252's Avatar
Speed is everything
Dart Iron Eagle heads are some of the best cast iron heads you can by.
boss252 is offline
Old 01-12-2007 | 11:32 AM
PatriYacht's Avatar
Jim V can port a set of Iron Eagles like you wouldn't believe. They flow as good or better than any conventional aftermarket head.
PatriYacht is offline
Old 01-12-2007 | 11:56 AM
We have built multiple sets of Dart Iron Eagle heads. If You absolutely we want cast iron heads the Dart is the only way to go! PM me if you have any questions, I can lead you in the correct direction the first time around.
mrhorsepower1 is offline
Old 01-14-2007 | 02:32 PM
Sick Stinger's Avatar
Brotherhood #1
Hey Beak couple quick questions WHat AFR head did you use and also how much power were/are you makeing. I have a 502 with a B&M 250 with 750 Holleys makin 650 cast heads all roller how much gain is there over that.
Sick Stinger is offline
Andy
Wanted
6
03-19-2008 10:03 PM
ENFORCER24
34
01-26-2008 12:15 PM
JasonSmith
10
02-08-2006 08:12 PM
claykehrer
11-09-2004 11:31 AM
Dave1972
6
12-09-2003 02:16 PM
