cmi E tops
Old 01-24-2007 | 08:10 AM
Question cmi E tops
Im wanting to purchase some CMI headers . But I have a concern . I am running 572 tall decks with Brodix aluminum heads . Is there enough room between the 2 engines to install these headers. I currently run Merc Manifolds. When they were installed the Merc letters had to be ground off to fit . Are CMI,s any narrower?I run a 34 inch crankshaft centerline if this helps.The merc manifolds make 100% contact at the centerline of the boat .Tight as hel_ ..If CMIs wont work what will ? Thanks for the info ..
boatman747 is offline
Old 01-24-2007 | 10:46 AM
Too Old's Avatar
Default Re: cmi E tops
I believe you need 32 5/8" minimim with 1 7/8 inch primaries.
You might want to call Randy Lieder@CMI to verify.920-722-7084
Fred
Too Old is offline
Old 01-24-2007 | 10:54 AM
I did talk to Randy. He was alot of help ..Thanks
carter38
Swap Shop
4
08-05-2008 03:13 PM
kennyo
Wanted
5
07-07-2008 08:48 AM
runafever
Wanted
0
03-19-2008 04:23 PM
kmiller
07-08-2007 01:44 PM
tomtbone1993
04-25-2006 05:28 PM
