swim platform removal >
Old 03-01-2007 | 10:09 AM
Shore Thing's Avatar
Default swim platform removal
I'd like to remove my swim platform so that I can repaint it. The last owner of the boat had removed it before and when he re-mounted it, he used 5200 on the threads and in the holes.
Whats the best way to get this thing off? Drill out the bolts?
Shore Thing is offline
Old 03-01-2007 | 10:18 AM
Oh your gonna have some fun. When is the new motor going in the boat?
BobbyB is offline
Old 03-01-2007 | 12:26 PM
ST, you may want to try this stuff..............
http://www.debond2000.com/
ThruHull is offline
Old 03-01-2007 | 02:33 PM
offthefront's Avatar
It will come loose .. you just have to work at it ..make sure all the 5200 is cut away anywhere it is visible ..the Debond works but is slow ....WD40 will work too .. If you have the bracket type platform ...remove the bolts and then move the platform up and down but dont force it ...when you move the platform down you should be able to sqirt some Debond down the crevice ...go slow ...some people have put a heat gun on it to soften it up .... m
offthefront is offline
Old 03-01-2007 | 03:17 PM
Pat fired it up on the bench last weekend, so all that is left is waiting for some warmer weather. Depending on Pat's schedule, we'll probably drop it in late March.
This platform wouldn't be nearly as bad to get off if some didn't use phillips screws on half of the mounting holes. You can't exactly get leverage with a screw driver on a screw head that spend a good portion of its life dunked in salt water.
Luckily, the main throughbolts are actually hex bolts.
jharran
Advantage
3
03-21-2008 01:36 PM
jeff1000man
08-22-2007 07:31 AM
Baddogg
Pantera
7
01-09-2007 04:36 PM
rch662
Superboat
0
01-25-2006 02:17 PM
barron
Cigarette
3
01-02-2005 10:56 PM
