water pickups >
water pickups
water pickups
Old 03-11-2007 | 04:24 PM
Default water pickups
i have a 38' scarab, i was wondering if my pickups are slowing me down. they are located 4' forward of the stern. they are wedge shaped, and are 1 7/8 thick at the back. if i changed to a diferent thrue hull pickup, can i leave them were they are now ??
teddy38 is offline
Old 03-11-2007 | 05:09 PM
Ed
Default Thru-Hull Water Pick-Ups
What drives do you have & do your drives have existing water pickups in the sides? TRS drives, or?
Ed is offline
Old 03-11-2007 | 05:19 PM
i have konrads.
teddy38 is offline
Old 03-11-2007 | 05:26 PM
the thru hull is my only water.never had one blade of grass with these wedges, but there shaped like my trim tabs in a down position. dont know if it matters 4' forfard.
teddy38 is offline
Old 03-11-2007 | 06:05 PM
would transom pickups be better ??
teddy38 is offline
Old 03-11-2007 | 07:07 PM
cuda's Avatar
I have surface drives on my Formula, and a Trs on a 22 Classic. They both have the same type of transom mounted pickups.
cuda is offline
Old 03-11-2007 | 07:12 PM
johnnyboatman's Avatar
yes those will slow u down,
johnnyboatman is offline
Old 03-11-2007 | 07:59 PM
if i changed my thru hull pickups to the off shore thru hull pickups, they are to far forward and might not grab water without the wedges. it would be to easy to just change pick ups. has anyone tried it ??
teddy38 is offline
Old 03-11-2007 | 08:01 PM
do the transome pickups have screens in them ?
teddy38 is offline
Old 03-11-2007 | 08:45 PM
scottc's Avatar
Be sure to check the pipe in those pickups, I just replaced mine due to the pipe being stainless and the pu being alu. The will rot out and you will never know untill you start to overheat in strange ways.
scottc is offline
