Stock 330's Rocker Arms??????
I have two sets of used crane energizer roller rockers I'd sell for $100. They ran fine but made a little more valve train noise then I wanted, so I bought comp cams pro magnum rockers. The energizers are just laying around now taking up space.
BT
BT
The stock rockers will hit the rocker studs at anything more than .550 lift. There are long slot rockers that are stamped steel for higher lifts. However higher lifts usually mean higher spring pressures and /or roller cams. I wouldn't feel comfortable using stamped steel rocker arms for that.
